Closed Thread
Old October 9, 2013, 02:59 AM
sf101's Avatar
Default 7970 & 280x cross fire compatible confirmed
source
thanks to Brent_Justice @ hardforum.com
Can R9 280X CrossFire with HD 7970 GHz Edition? Will it Blend?
Question: After reading our AMD Radeon R9 and R7 Series Re-branding Introduction and ASUS R9 280X DirectCU II TOP Video Card Review, you may be asking yourself, if the R9 280X is a re-brand of HD 7970 GHz Edition, can I CrossFire both for a performance improvement? Will it work?
Test: ASUS R9 280X DirectCU II TOP CrossFire with Reference Radeon HD 7970 GHz Edition video card. Single CrossFire cable atop the video cards.
Result:
- Catalyst Control Center Confirms CrossFire Enabled
- Catalyst Control Center Confirms a Primary GPU with a Linked GPU under Hardware Info
- GPUz confirms 2 GPUs enabled (CrossFire)
- Crysis 3 confirms "MGPU 2X" mode present in AA settings
- Crysis 3 confirms expected performance increase with two GPUs installed
- Running Stable in Crysis 3, no bugs or crashing
Summary: CrossFire of retail card R9 280X and 7970 GHz Edition reference card = 100% success
My 5 Current Rigs-Guest-Main-Work/Spare-HTPC-Laptop
I7-6700T-Work
3770K@ 4.8GHz -Main
2500k @ 4.7GHz -Guest PC
3570K @ 4.5 -HTPC
MSI GT70-2OC/770m-998/4800MHz -Laptop
SF101 HW BOT
Crossfired XFX290X@1150/1500mhz-EKWB (Main)|GIGA-OC7970WF3@1250/1850 (HTPC)
MSI 970GTX (Guest) ||Asus480GTX@900/2000 (work)
Old October 9, 2013, 06:53 AM
Dzzope's Avatar
I don't see how there is a crossfire cable across the cards as the r9 etc have no crossfire connector.
Besides, you could crossfire different cards from AMD anyway AND 7970's are showing up in certain things as 280x's (and the ghz version is really just an oc'd stock one.)
Random quotes:
AKG: "So please don't piss on people and claim its raining. "
Soullessone21: "Their the only fat bitches I ever want in my wife :)"
DeeraxTheCoolNemo: "I never preSs CaPLoCK I just HiT my keyS so Hard ThEY Crit"
Old October 9, 2013, 08:11 AM
Crossfire (And SLI) doesn't require a bridge in some applications. with PCIe 3, the bus is probably fast and wide enough to not require one even for the high end cards.
Old October 9, 2013, 08:30 AM
I have not seen one of these cards yet but in the HWC review here I read ". . . the R9 280X uses a pair of physical Crossfire connectors allowing for up to three cards to be used in tandem."
I guess they do have a Crossfire Connector. Any one confirm this?
I wonder if the HD 7970 would have to be a Ghz version or will any HD 7970 work?
________________________________
FKD
Fort Kent, Alberta
2012 - A10 Rig
Old October 9, 2013, 09:04 AM
The bridgeless technology does bring up a few questions, especially with connectors on the cards.. Maybe it's just a legacy thing?
Either way I'd imagine it being basically the same under the hood, that any edition would work.
Old October 9, 2013, 09:15 AM
great_big_abyss's Avatar
Is it possible that the bridgeless technology is relegated solely to the 290x?
Or maybe it was all just a baseless rumour.
I suppose we'll know more about it when the 290x review comes out.
Old October 9, 2013, 12:39 PM
Killswitch's Avatar
I'm pretty sure the answer is.... yes. But don't forget about the 290.
Old October 9, 2013, 04:26 PM
Dzzope's Avatar
Yea.. my bad.. Must have mis-read. Either that or they are just using the same PCB as the 7970?
Random quotes:
Old October 9, 2013, 04:35 PM
Killswitch's Avatar
Some partners will be using the same layout, others aren't. But I bet all 280x's will have CF connectors.
Quote from Sky's review... "After talking to board partners, it seemed that many would be using the same card designs for the R-series as they did for custom HD 7000 products..."
Old October 9, 2013, 07:23 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Continue conversation here: Will it Crossfire? R9 280X & HD 7970 Scaling Tested (Comment Thread)
Closed Thread
AMD R9 280X, R9 270X & R7 260X Review Comment Thread SKYMTL Video Cards 55 November 11, 2013 07:16 PM
Should I buy another graphics card to run in cross-fire or buy a single one? melonpaste Video Cards 18 August 21, 2011 11:38 PM
new to cross fire have a question or two Shadowmeph Video Cards 1 May 5, 2010 10:58 AM
which cheap case to get for a cheap cross fire setup running on air Shadowmeph Cases 22 January 12, 2010 09:03 PM
