  #21 (permalink)
Old September 20, 2013, 07:39 PM
Default Eyefinity and Mixed Monitors
Originally Posted by draemn View Post
FYI:
For Surround (2D), you can use different monitors sizes. However, each monitor must display the same resolution - and they will default to the lowest common denominator. ....
I think that's how my Eyefinity works too.
My center screen is a 24" LCD while my two outside monitors are 20" LED. (Yes it took some fiddling to get the blues to look the same across all three monitors - and there is still a difference but I can live with it until I replace that middle screen with an LED).
Anyway, looked up the resolution on the centre monitor and it is 1920x1200 - yet my 4800x900 eyefinity display is 3x1600 x 900. So my center screen is not at it's full resolution. But the image quality if fine for these old eyes. It a LG 2452T while the outside ones are LG.E2040T
Is there a way to define the centre screen as a different resolution than the two outside ones in eyefinity? I'll have to see what I can learn about that idea. Not sure how it would work when the system is treating the display as one big screen.
________________________________
FKD
Fort Kent, Alberta
2012 - A10 Rig
  #22 (permalink)
Old September 20, 2013, 08:26 PM
Well, well, there was a mini displayport to regular displayport adapter in the box.
And I found that there is a $30.00 MIR - lets see if that gift card arrives. (I'm always pessimistic about MIR to rural P.O. Boxes)
Guess I'll have to swing by Memory Express on the way out of town and get a refund of $12.28 on that adaptor - dang I wish I knew that when I bought it - or better yet, had a salesman who would have pointed this out.
FKD
Fort Kent, Alberta
2012 - A10 Rig
  #23 (permalink)
Old September 20, 2013, 08:56 PM
I honestly don't know, but I doubt it. IF it is possible, you'd have to hook up 3 monitors NOT in surround/eyefinity mode and just use them as 3 single monitors... which means no multi-monitor gaming.
  #24 (permalink)
Old September 23, 2013, 07:03 AM
Default Installed and Working
Installed the HD 7970 when I got home - booted her up and it works.
It was late so really didn't get much of a chance to take it for a spin - it seems to run X-Plane well enough - 30ish FPS with the settings pretty much maxed out - I was 15-20 with the settings turned down to medium. Even with HDR on I didn't see a drop (or increase from) the 30 ish level. Will need to test more to see how it maintains those levels. GRID (original) went from about 25-30 fps to 60, again thats with an increase in settings to max levels (which didn't seem to make a difference, 60ish at whatever rendering level I chose.
Make use of every cm of clearance in my new rig. I could rotate the hd cage or remove it altogether if I needed more space, but with the cage rotated for max air flow I only have a couple of cm's of clearance - I think you can see that in the photo below.
Also dropped in my new 140 red led fans and my new 3T hard drive.
FKD
Fort Kent, Alberta
2012 - A10 Rig
  #25 (permalink)
Old September 23, 2013, 07:20 AM
great_big_abyss's Avatar
Awesome. Looking good! Enjoy that beast of a 7970! Sounds like you're happy with it!
  #26 (permalink)
Old September 23, 2013, 11:45 AM
Been noticing that my background images don't line up like they used to, checked the screen resolution - its now 5024-900. Hmmm? It gives the option to go down to 4800 x 900. Tried it both ways so far I can't really make out much of a difference. Curiously it is only the horizontal resolution and not vertical. Also Catalyst reports the resolution as 5024x900 yet says maximum resolution is 4800x900. Hmmm? Curiouser and curiouser. I'll leave it at 5024 and just see how she goes.
FKD
Fort Kent, Alberta
2012 - A10 Rig
  #27 (permalink)
Old September 23, 2013, 01:01 PM
Dzzope's Avatar
Bezel correction?
Random quotes:
AKG: "So please don't piss on people and claim its raining. "
Soullessone21: "Their the only fat bitches I ever want in my wife :)"
DeeraxTheCoolNemo: "I never preSs CaPLoCK I just HiT my keyS so Hard ThEY Crit"
  #28 (permalink)
Old September 29, 2013, 10:54 PM
Default Some Results with my new HD 7970
Well I ramped up the settings on one of my newer games, Dirt 3 and turned on FRAPS to see how my new card was performing. All the settings are on max (ultra). My screen is now 5024 x 900 (didn't think changing my video card would change the resolution but it did - used to be 4800 x 900).
FRAPS report on 207,000 frames showed an average of 57. Curiously the max was 64 for there isn't a lot of deviation from the max.
I like it.
Also loaded 3D Mark 11 and ran the tests. Compared to other A10's running HD 7970's my system comes out middle of the pack with a score of P6939. (my HD 6670's had a score of P1876 for comparisons so this is a big step up for me). I know that's not a great score in Mark11 as I see scores three and four times as high, but I'm in the middle of the pack and there are many different systems with a wide assortment of CPU's that score about the same as I did. I have not over clocked this card - (unless you count the factory set OC as this is the OC card).
Re-ran the test, 7019 this time.
FKD
Fort Kent, Alberta
2012 - A10 Rig
  #29 (permalink)
Old September 30, 2013, 01:31 AM
Dzzope's Avatar
With those frame-rates I would guess v-sync or something is limiting you? Or maybe the APU?
But it really does look like your hitting a bottle-next or some sort of limit to have such a tight fps range
Random quotes:
  #30 (permalink)
Old September 30, 2013, 07:37 AM
Default Arn't my FPS in ballpark?
I did enable v-sync and 8xAA. Maxed out everything.
My FPS is in the same ballpark as the review done by Wide Screen Gamer's Forum.
They show a HD7970 getting about 55 at 4800x900. (mine is 5024-900). And they ran that on an Intel i7 2600k at 4x3.4GHz system. If my A10 competes favorably with an i7 I think I'm doing well.
AMD Radeon HD 7950 Review - DiRT 3 | WSGF
FKD
Fort Kent, Alberta
2012 - A10 Rig
Official ATI Eyefinity/nVidia Surround Discussion Thread SnoSalmon Display Units 245 March 3, 2014 09:32 PM
1500$ eyefinity/surround system stolendo New Builds 13 June 25, 2013 02:07 AM
ASUS VN247H - The Ultimate Surround/Eyefinity Monitor? draemn Display Units 2 April 18, 2013 12:02 PM
Question on surround/eyefinity Beastylemon Display Units 7 September 30, 2011 11:35 AM
5.0 surround speakers for PC? Lima Audio 5 September 27, 2010 08:31 AM
