  #31 (permalink)
Old September 28, 2013, 09:14 PM
Originally Posted by xxx View Post
got it replaced by the seller still the same problem
Does your power supply have the proper connectors for your GPU ? Or are you using any adapters?
  #32 (permalink)
Old September 29, 2013, 01:53 AM
xxx xxx is offline
it has one six pin and a eight pin connector
  #33 (permalink)
Old September 29, 2013, 07:30 AM
Dzzope's Avatar
I'm thinking it's possible that the CPU is bottle-necking the card in some CPU heavy, not multi-threaded games? Particularly at 1600x900..
Whats your cpu usage at? is your cpu over clocked?
Random quotes:
AKG: "So please don't piss on people and claim its raining. "
Soullessone21: "Their the only fat bitches I ever want in my wife :)"
DeeraxTheCoolNemo: "I never preSs CaPLoCK I just HiT my keyS so Hard ThEY Crit"
  #34 (permalink)
Old September 29, 2013, 12:36 PM
xxx xxx is offline
cpu usage around 75-80% yes i have ocd my cpu to 3.8ghz
  #35 (permalink)
Old September 29, 2013, 01:03 PM
sf101's Avatar
If it was me i would.
get a temp monitor and leave it on and see what highest temps while gaming are.
get gpuz and leave it on sensors mode to monitor temps and performance / core speed and usage changes. .
run prime 95 with cpuz on to see if cpu performance is throttling down with temp changes.
play game and see what these temps are getting too.
your cpu could be throttling or your gpu could also be throttling.
also if this is not the case and the temps are still within lower than 65*C range then i would bump your gpu voltage with msi afterburner software a tad and see if that stabilizes the freeze ups.
when you decided to overclock to 3.8ghz on the phenom 2 did you add a good aftermarket cooler?
once you figure those things out it will give us a better over all awareness of what is going on here.
also make sure core parking is off - cpu is set to 100% idle / max performance in the power management while testing.
My 5 Current Rigs-Guest-Main-Work/Spare-HTPC-Laptop
I7-6700T-Work
3770K@ 4.8GHz -Main
2500k @ 4.7GHz -Guest PC
3570K @ 4.5 -HTPC
MSI GT70-2OC/770m-998/4800MHz -Laptop
SF101 HW BOT
Crossfired XFX290X@1150/1500mhz-EKWB (Main)|GIGA-OC7970WF3@1250/1850 (HTPC)
MSI 970GTX (Guest) ||Asus480GTX@900/2000 (work)
  #36 (permalink)
Old September 29, 2013, 01:27 PM
xxx xxx is offline
gpu max temp 72c
gpu usage in ac3 58-90% (58,60,90,47,70,71,76,86,67,90,61,65,90,51,55%usag e)sometimes gets down to low 5-6% it is only in ac3
cpu max temp 45c
usage at default speeds 60%
  #37 (permalink)
Old September 29, 2013, 02:56 PM
xxx xxx is offline
when i run msi kombustor the gpu was running at 95% but as soon as i ran prime 95 the gpu usage started varrying
  #38 (permalink)
Old September 29, 2013, 09:31 PM
xxx xxx is offline
i think its cpu any thoughts
Ram running at 1.5v supaflyx3 RAM 1 April 23, 2013 05:57 AM
Anybody here still running c2d or c2q CPU? mrrhtuner CPU's and Motherboards 40 October 5, 2012 07:46 PM
HDD running very hot fire_storm New Builds 19 August 15, 2010 05:51 PM
Is my gtx 480 running hot bvsbutthd101 Video Cards 32 June 30, 2010 10:08 PM
Running RAM 1:1 still the best? biff RAM 12 January 29, 2008 07:30 AM
