  #21 (permalink)
Old September 22, 2013, 08:07 AM
LoTech's Avatar
I meant try to swap "your" video card into a friends system. You could try that PSU in your system it should be fine for the 560 gpu.
p://www.hardfolding.com/fhtag.php/mem/7984290/26/1.png[/IMG][/url]
  #22 (permalink)
Old September 22, 2013, 07:55 PM
xxx xxx is offline
3d mark vantage
3d mark 11 basic
my gpu core speed 549 mhz is it normal
  #23 (permalink)
Old September 22, 2013, 09:26 PM
xxx xxx is offline
on 4x slot the gpu usage furthur reduced.
  #24 (permalink)
Old September 22, 2013, 09:29 PM
Another member had an issue like this with a 560ti and no matter what they did it would not run at its proper speeds.
If I remember he had to install MSI Afterburner and downclock the card to run at a slower speed. I suggest trying this first and it fixes it you need a new card or get it replaced.
  #25 (permalink)
Old September 22, 2013, 09:34 PM
supaflyx3's Avatar
Yup that was me, I tried everything from different drivers to overvolting, and undervolting and none of those solved it, so i downclocked it by 50mhz to 850mhz and it worked fine.
  #26 (permalink)
Old September 23, 2013, 09:25 PM
xxx xxx is offline
is that means the gpu is weak and i will not be able to oc the card.
when i increase the core by 140mhz & ram by 150 it passed the stress test but as soon as i launch the game the game stops working.
  #27 (permalink)
Old September 24, 2013, 05:12 AM
xxx xxx is offline
i under clocked the card and ended up with max of -102mhz on core &-502 mhz on ram still there is no performance
i have installed it on another system still no difference.
  #28 (permalink)
Old September 24, 2013, 06:36 PM
xxx xxx is offline
when i play older games like bf3,justcause2,nfsthe run all run well with 98-99% gpu usage but as soon as i run ac3,crysis3&splinter cell blacklist they run terible with low50-60% gpu usage some times climbes to 90%.
or should i simply rma
  #29 (permalink)
Old September 24, 2013, 06:59 PM
Your_friendly_gamer's Avatar
yes just rma it, frigging headache it seems.
  #30 (permalink)
Old September 28, 2013, 08:29 PM
xxx xxx is offline
Unhappy
got it replaced by the seller still the same problem
Ram running at 1.5v supaflyx3 RAM 1 April 23, 2013 05:57 AM
Anybody here still running c2d or c2q CPU? mrrhtuner CPU's and Motherboards 40 October 5, 2012 07:46 PM
HDD running very hot fire_storm New Builds 19 August 15, 2010 05:51 PM
Is my gtx 480 running hot bvsbutthd101 Video Cards 32 June 30, 2010 10:08 PM
Running RAM 1:1 still the best? biff RAM 12 January 29, 2008 07:30 AM
