Old September 6, 2013, 08:51 PM
Default Updated Catalyst - Lost Dual Graphic Option
Now this will only matter to the select few of us on the planet that have two graphic cards installed on an AMD APU system. Before I updated my catalyst drivers I used to be able to disable crossfire - and then when I re-enabled it the system asked if I wanted to pair the GPU with the APU or the other GPU - I had some fun seeing if dual-graphic mode (paired with the APU) was any better or worse than the standard crossfire when the two HD 6670's were crossfired with each other. These cards do not use a crossfire adaptor and crossfire through the motherboard.
Anyway, that option is gone. Not that I used it much having found that the two GPU's crossfired tended to be slightly better than the APU-GPU Dual Graphics mode. In theory they should have been pretty much the same.
I found this out because I had decided to load the Lucid program which came with the mobo - ASUS had an update for Win8 64 bit so I decided to give it a go. No can do, only works with the APU-GPU set up not in normal crossfire. Oh well - no great loss.
________________________________
FKD
Fort Kent, Alberta
2012 - A10 Rig
[FS] Dual D5strong + EK dual serial top + 24v dual controller $185 Shipped in Ontario canada2005 Buy/Sell & Trade 12 August 30, 2012 03:53 PM
AMD Releases 10.12 Catalyst Drivers & Redesigned Catalyst Control Center FiXT Press Releases & Tech News 4 December 14, 2010 07:04 PM
AMD Releases Catalyst 10.8b hotfix For Dual GPUs and HAWX 2 FiXT Press Releases & Tech News 3 September 11, 2010 09:46 AM
Dual boot default OS option headsh0t O/S's, Drivers & General Software 6 February 8, 2010 08:35 PM
Catalyst crash when running dual monitors jeep11 Troubleshooting 0 December 25, 2009 08:23 PM
