Old September 3, 2013, 10:57 PM
Default 2 sapphire 7950s similar Overclock very different 3dmark Results
I got 2 sapphire cards , but I got 2 different versions. One card came with the following sku : 11196-01 stock card came at 810mhz and 1250mem. This card came clocked at 1.093v as per trixx. I ran many runs in Heaven and was able to achieve the following performance before hitting the maximum clocks of 1220/1500 at 1.25v.
The second card I got was the boost OC edition which came with a clock of 925mhz and mem of 1250 but the voltage as per trixx was set at a default 1.25v. I was able to boost core to 1180 and memory seems to be between 1600-1700( didnt finish final tests, have to go to bed).
Upon completing the tests and finding my maximums I decided to get a 3dmark Performance score to guauge my results. I was able to achieve 9776 on the non-oc version (11196-01) and 8360 on the OC version (11196-19).
I find this odd because the difference in clocks is 20mhz on the core for the non-OC and 150mhz on the memory in favor of the OC .
Could someone explain to me why there is a gap of 1400 score between the two? Did I miss something. I have a detailed write-up of my runs with Heaven
thanks for the help!
Here are the details of the first cards runs in Heaven. and the 3dmark scores for both.
11196-01
mhz-minFPS-maxFPS-temp
1050-24/108-55
1070-9/119-65
1080/1112v/34/141-66
1100/1131v/22/126-67
1120/1153v/22/128-68
1140/1173v/25/130-69*************
1160/1193v/24/131-72
1180/1213v/24/133-72
1200/1233v/24/134-75
1220/1253v/26/136-75--1250
1220/1253v/26/143-76--1500
SKU of card: 11196-01
---- STABLE 3DMARK
1200/1231v/1450mem-75*****3dmark success 9776
SKU of card: 11196-19
1180/1262v/1600mem-65*****3dmark success 8360
Old September 4, 2013, 01:57 PM
The card with the higher voltage is also resting at a lower temperature. Is it being throttled somehow? Is the cooling the same on the card?
Old September 5, 2013, 09:41 AM
well the thing maybe the oc is not stable.
also like the guy said on top the card could be going up and down.
also maybe 1 card has boost and is hitting better clocks.
you should check to see what the card is doing
in afterburn it should be a straight line no going up and down.
Old September 5, 2013, 09:43 AM
7950 are ment to be overclocked :P
Old September 5, 2013, 10:52 PM
I have gotten suggestions to set power controls to +20% on the Boost edition card which is the one that seems to be lacking in benchmarks, even though it is similar in core clock at 1180 and mem at 1600. I didnt pay attention to graph before however I just tried the +20% and the GPU core load in GPU-Z is straight line. However I do think this might be the whole boost/throttling on the OC card.
The cooling is identical! the cards look same... only different color pcbs and different outputs on the back. Also one has a little switch for the 2nd bios and the boost card has a push-type button for the second bios.
I think I will try more testing with +20% and try to use second bios to OC
thanks for all the help guys!
How high can I overclock my Sapphire HD7950 Vapor-X ern88 Overclocking, Tweaking and Benchmarking 7 March 6, 2013 02:58 AM
Sapphire HD 7770 Ghz Edition - Overclock TpeBoMaH Video Cards 2 January 7, 2013 05:12 PM
What is the difference between these two 7950s? p3t3r1 Video Cards 1 September 1, 2012 06:28 AM
Innovation Cooling 7 Carat Diamond TIM Test results thread *NOW ACCEPTING RESULTS!!* Nademon Overclocking, Tweaking and Benchmarking 254 December 14, 2011 09:18 PM
q6600 overclock results; pls critique! Mavspire Overclocking, Tweaking and Benchmarking 3 March 11, 2009 01:49 AM
