Old September 1, 2013, 08:34 AM
trodas's Avatar
Worser than that, a bad PSU could damage/kill all your components. And since this is a powering or cooling issue, then unless the fan stop (and it doest not, because if it do, the the temp will shoot much higher), it had to be the power issue.
What card you had in use before this Asus GTX 650 Ti...?
"It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
"I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway :) my config - my caps
Old September 1, 2013, 08:58 AM
KaptCrunch's Avatar
Originally Posted by enaberif View Post
Get a new psu that thing is garbage.
yes for only 432watts (divided on 2x12v rails) available not the 650 as advertised
Old September 1, 2013, 09:43 AM
Bond007's Avatar
Yeah I would say its driver conflicts, or a bad psu. What was your previous graphics card?
Old September 1, 2013, 10:15 AM
rjbarker's Avatar
Do you have nv HD Audio Driver installed, it will default install when you install nv Drivers (Custom install is the way to go as you can uncheck it).....these have been known to cause CTD (Crash to Desktop) and/or Blackscreens.
Disable it in Device Manager.......if problem continues definitely replace your PSU
Firestrike Extreme: 21.452
MARK 11: 32.530
Old September 1, 2013, 10:57 AM
IRQ Conflict's Avatar
Originally Posted by moocow View Post
I thought Driver Sweeper is discontinued.
The latest version can be found here. Apparently the developer(s) of Driver Sweeper have gone commercial. For 17 bucks you can download their Treexy "Driver Fusion" which does the same thing. So far, I have found Driver Sweeper to still work so...
Old September 1, 2013, 03:49 PM
xxx xxx is offline
My old gpu was gt 210.
ok i disabled nv high defination audio from device manager
now my card is working fine.
should i run msi combuster to check if my psu is powering enough to my gpu.
Old September 1, 2013, 04:08 PM
The old vs new card would require almost NO power at all. The newer card is drawing a lot more power.
Old September 1, 2013, 04:30 PM
Dzzope's Avatar
Could very well be the PSU... those coolermasters are not any good at all.
If you can get a friend to pull theirs to test or take to a local store and ask if they can test for you with a different PSU.. Throw them $10 or something for the trouble.
Random quotes:
AKG: "So please don't piss on people and claim its raining. "
Soullessone21: "Their the only fat bitches I ever want in my wife :)"
DeeraxTheCoolNemo: "I never preSs CaPLoCK I just HiT my keyS so Hard ThEY Crit"
  #19 (permalink)
Old September 1, 2013, 04:44 PM
xxx xxx is offline
want to buy a psu after 3-5 months till that i will use my older psu
any psu ????
  #20 (permalink)
Old September 1, 2013, 05:29 PM
Dzzope's Avatar
Get a bronze(or higher) rated something... read review, good quality 550 - 650 W will be plenty.. Just read professional reviews on them.
I say bronze cos you have mid level rig and gold or platinum will be very expensive compared to your other bits..
Though if you do go gold rated it should last you a few builds.. Remember to read proper (not customer) reviews.
Random quotes:
Gaming crashes my pc clouter Troubleshooting 18 December 19, 2011 12:55 PM
P95 crashes Goalieman077 Troubleshooting 2 October 14, 2009 07:59 PM
random crashes tom.mullie Troubleshooting 14 November 23, 2008 07:20 AM
New computer, new crashes Asspigeon Troubleshooting 48 October 14, 2007 05:48 PM
