Old April 28, 2008, 07:06 PM
Default Do 9800GTX share the same clock speed increments as 8800 Series?
http://www.overclock.net/hardware-ne...ng-tables.html
If you read this thread from here from a while ago it states that the 8800 series GPU clock actually raises in increments rather than every 1MHZ. So does the 9800 GTX share the same increments??
I just got my 9800GTX and want to jump into Overclocking it but would like to know when the Clocks for the Core/Shader/Mem jump to the next increment?
Does anybody know for sure when the Clocks make their jumps?
Thanx!
System spec: Intel i7 2600k, Gigabyte GTX 570 Super Overclock, Kingston DDR3 2X4 GB sticks, ASUS P8P67 PRO, Cooler Master 700 watt PSU, 750GB*2 Sata,SATA III 1TB HDD Acer 24 Widescreen, Antec 300, Windows 7 Ultimate 64 Bit
Old April 28, 2008, 07:36 PM
Just do it and find out? I think Riva tuner lets me set 1mhz increments I've never verfied that with the actual core speed though.
Lemme check
ok from 675 I got 678.86 as the next jump up, and I had to set 680 to get that. Hope that helps.
CPU: E4500@3.3ghz ( 300X11@1.430v) MB: DFI LanParty ICFX3200 T2R/G
RAM: OCZ Platinum XTC rev2 ( 4-4-4-15 2t ) GPU: BFG 9800GTX
COOLING: Swiftech 120 Compact - Swiftech - MCW30 SOUND: HT omega Striker 7.1
CASE: NZXT Lexa Blackline PSU : OCZ Gamestream 700w
Old April 28, 2008, 07:44 PM
I was just wondering if anyone had a full table for all clocks for when they jump. I guess I find out for myself. I'll post it when I know.
Old April 28, 2008, 08:03 PM
3oh6's Avatar
Hardware Canucks Reviewer
no one has made a table yet that i have seen, and i doubt anyone will, but they do jump in increments. you can set 1MHz increments in RivaTuner and in GPU-Z they show up as what you set...but if you use the RivaTuner monitor, it will show you the actual changes in frequency.
Old April 28, 2008, 08:49 PM
I wish I had the time to make a proper chart showing all the jumps. It will prolly take me a week to get it done.
BTW, GPU's don't need a break-in period do they? Is it alright to just go for the gold right out of the box and try for max speed??
I hit 704/1782/2200 No problem on just a quick check. I really like the Auto fan on this GTX. It is very responsive to temps. Goes up and keeps adjusting itself according to temps. When I set the Fan to 90% my Temps dropped to 40C!!!!!! Very nice and cool. can't wait to max this puppy out and see what she has.
Old April 28, 2008, 08:58 PM
3oh6's Avatar
within 10 minutes of firing up my 9800GTXs up i had each one of them over 800MHz. stock coolers set to 100% and no volt mods, they all ran 820MHz~830MHz stable for benching. so yeah, should have a good bit more in it.
obviously there is the risk of damage when pushing anything so go slow, take your time, and keep an eye on temps. also, if you set the fan to 100% and during benching the fan speed drops to 35%, don't be alarmed. this is a problem NVIDIA hasn't been able to fix yet. basically, when the card reaches 60C or around there, the fan kicks down. this might just be happening in SLI though, not sure.
Old April 29, 2008, 07:00 AM
No it happens all the time. Oddly if you dont set 100, say like 60, I can get it to idle at 47deg.
Old April 29, 2008, 07:27 AM
3oh6's Avatar
yeah i shouldn't have said manually set to 100%, it will do it no matter what the fan speed is set to. kind of a hassle as there is plenty left in these cards for benching with just the stock cooler...if the fan speed would stick. even with volt mods, the stock cooler holds its own. i can bench at 870MHz on all cards with vGPU up to 1.35v...but temps make the fan kick out in 03/05/06...01 is still easily benchable.
