Old July 20, 2013, 04:16 PM
Default That annoying gpu usage spikes bug!
So,i have had this problem for 3 years now,when browsing the web,aero suddenly disables itself and i have gpu usage spikes from 0 to 99%... Which kind of software does that,aero bug? Also happened with my old card :( do you have any ideas?
Thanks.
Old July 20, 2013, 11:55 PM
Dzzope's Avatar
Tell windows to ignore it.
Random quotes:
AKG: "So please don't piss on people and claim its raining. "
Soullessone21: "Their the only fat bitches I ever want in my wife :)"
DeeraxTheCoolNemo: "I never preSs CaPLoCK I just HiT my keyS so Hard ThEY Crit"
Old July 21, 2013, 12:24 AM
IRQ Conflict's Avatar
How do you tell windows to ignore the GPU when it gets loaded to 99%?
bliz, need more details. When was the last time you did a clean install of windows? What other GPU's were you using in the past that did this? Same driver? My guess is the driver, and or improper install. Messed up registry.
Old July 21, 2013, 01:00 AM
Dzzope's Avatar
I mean tell windows to ignore the aero thing.. ie "your graphics aren't good enough, turn aero off blah blah"
From what I've seen this has happened with my last 3 Graphics cards but has never actually impacted performance. Tell windows to ignore, unless it is impacting performance.
Random quotes:
Old July 21, 2013, 01:55 AM
Sure, but that doesn't fix having the GPU pinned to the wall just surfing the net.
Does the GPU still get loaded up if you manually disable aero?
Old July 21, 2013, 04:23 AM
Dzzope's Avatar
It doesn't put load on it (as in the card isn't stressed from what I've seen) in that it will stay at idle voltages and power etc, usage just goes to 100%.
heat doesn't go up (much, couple of deg maybe) and fans don't ramp up either.
If it's actually putting full load on it then yea, try fix, otherwise just set aero to ignore it.
Random quotes:
Old July 21, 2013, 07:54 AM
Thanks.
what browser do you use?
Old July 23, 2013, 03:02 AM
Sorry,i'm back, Enaberif, i'm using chrome.
Btw, not the same drivers,it's probably related to chrome or windows...
I'm not at home at the moment (on laptop) but when i'll be back i'll try to disable AERO.
Old July 23, 2013, 05:37 AM
Google Chrome GPU Acceleration Crashing On You? Here?s the Fix
Use the disable composition flag
Old July 26, 2013, 10:07 AM
Ah nice! Thanks i'll try that!
hd 6970 directcuII spikes and stuff everywhere... Zer_Vako Troubleshooting 19 August 17, 2011 03:18 PM
Ping Spikes Every 8 Seconds? Realityshift Networking 10 December 13, 2010 09:36 AM
So annoying Kilauea HardwareCanucks F@H Team 7 January 27, 2010 07:50 PM
Lag Spikes!!! automatic Networking 3 February 1, 2009 12:53 AM
Constant Ping spikes Phobia Networking 10 July 24, 2008 06:26 PM
