Old July 18, 2013, 06:28 AM
Default GPU boost 2.0 with GPU tweak
Hey guys,i actually never used any GPU boost technology ever,and i have GPU boost 2 with my 770,i'm also using GPU tweak,and i had a few questions:
My card is running at a higher frequence than the official boost clock of that pre overclocked card , 1168 instead of 1110,is that normal? It won't clock higher than 1168 even if the temps are cool and it won't even boost to a lower frequence. Btw,when i overclock manually the card and i say 1130 core clock instead of 1110 it raises the actual in game clock,for example,1180 instead of 1160, it's like if the gpu written clocks on paper were wrong
Should i modify GPU voltage if i wanna overclock or is it automatic?
power target by default to 100 and it's already linked to temp target so i set temp target to 80 and the power target is 100%
Memory clock i don't care it's already 7ghz lulz.
Old July 18, 2013, 06:38 AM
great_big_abyss's Avatar
As far as I understand it, if your card has the thermal headroom to clock over the boost clock, then it will do so. If you would like to increase the boost clock 'target', you can increase the power target, then increase the frequency of the boost clock. It seems very easy and intuitive. But, frankly, these cards run fast enough that I didn't feel the need to overclock mine after the initial 'fracked around with it' stage. I returned it to stock clocks and called it a day. Now if it boosts higher in-game, right on...
BTW, I'm getting >70FPS in BF3 on Ultra @ 1200P. How about you?
Old July 18, 2013, 07:02 AM
Yeah i know right,i just wanna understand how it works,no need to overclock it this year :P
Sorry i don't have BF3 installed :( I can't tell but it must be pretty similar, depends on your clocks,i run 1168 all the time in any game so if you are close to that it must be pretty similar!
Even if your CPU is way better i don't think it gives you a huge FPS inprovement in BF3,which is mostly GPU intensive,i think i'd get about 65 fps^^
Wait i will give you my unigine valley score if you want :P
ultra 1080p x8 full screen and no vsync
46.9 average FPS
Old July 18, 2013, 07:07 AM
Hmmm...Valley. I haven't run that since I got my new processor/GPU. I'll run it this evening and post results in the Unigine Valley thread!
Old July 18, 2013, 07:08 AM
Oh there is a valley thread? cool i will check that out
Old July 18, 2013, 07:10 AM
Unigine Valley Benchmark Scores
Old July 18, 2013, 07:12 AM
elmorejohn46's Avatar
If you set the power limit to all it a go ,it will overclock itself untill it hit a certain temperture.If you set the voltage all the way up it will go higher.It is hard to really tell what clock you are rumming unless you set GPU-z to record and run a benchmark.
Intel-i7-3820+Corsair H-100+Gigabyte X79-UD5+16g G.Skill 1666DDR3+256g Crucial-SSD+1-3TB Seagate+2-1TB-Samsung+1-640g- WesternDigtal+SLI-ASUS DIRECT CU II GTX-670+LG-12x Blurner+Logtech G9x-mouse+G-110-keyboard+Driving Force GT Wheel+Pioneer VSX-1020K+Polk Audio Speakers+LG-50"Plasma PM6700+Antec-P280+XFX 850w PRO Semi-Modular
Old July 18, 2013, 08:09 AM
Dzzope's Avatar
From what I've seen in GPU boost 2.0.. max out your voltage (it's a tiny jump), max out your target power and basically you can bump the rest around to optimize it (memory and gpu speed and stability) but you will always be limited by the power.
Even if you don't want to play with the memory or gpu speed, max out the power and voltage.
The card will automatically raise and lower these within it's limits, all your doing really is setting the max allowable limits. Which are pretty well tied up by nvidia so you can't make the card go pop.
Random quotes:
AKG: "So please don't piss on people and claim its raining. "
Soullessone21: "Their the only fat bitches I ever want in my wife :)"
DeeraxTheCoolNemo: "I never preSs CaPLoCK I just HiT my keyS so Hard ThEY Crit"
Old July 18, 2013, 09:04 AM
Yeah lol the maximum is +12mv.................
Old July 31, 2013, 02:45 PM
Meh :( new problem,reinstalled windows on SSD,reinstalled gpu tweak,and now i don't have all the sliders. No voltage control slider and no temp target slider :( Do you know why?
Asus/Benq/Samsung 120 Hz LightBoost TWEAK: Zero motion blur LCD; Looks like CRT!! mdrejhon Display Units 109 December 23, 2013 08:51 AM
Help me tweak my OC! Pabz0r545 Overclocking, Tweaking and Benchmarking 1 June 3, 2012 02:08 PM
Overclocking the ASUS GTX 580 Voltage Tweak Edition Comment Thread SKYMTL Video Cards 45 December 24, 2010 05:47 PM
Nvidia & ATI Catalyst Tweak Guide Gameplaywarrior Guides & How-to's 3 February 12, 2009 09:19 AM
