Old July 7, 2013, 02:06 AM
bissa's Avatar
Default GPU fitting issue
my 560TI is starting to show serious problems with the memory, so I'm looking at upgrading. it seems like the gigabyte windforce 760 and the twin frozr 4 760 are pretty good options, but both are just a tiny bit too long for the specified max length for my case (fractal design define R3 [~290mm]) but since it has that ~ I'm wondering if they are saying that for cards with the power coming out the back or something.
is it possible to squeeze one of those into my case? or if not as they are, how modifiable are they to lose some length if at all?
Strong like hummingbird, swift like oak.
I'm sorry july, I couldn't see you behind all that feruary.
Old July 7, 2013, 04:58 AM
The RealRollo's Avatar
ASUS GTX670-DCMOC-2GD5 - Graphics card - GF GTX 670 - 2 GB GDDR5 - PCI Express 3.0 x16 - 2 x DVI, HDMI, DisplayPort at TigerDirect.com
I'd pay the extra for one of these or similar before I'd start sawing on a regular size one.
Old July 7, 2013, 05:03 AM
bissa's Avatar
yeah, most of the other 760s are small enough to fit, but the gigabyte and the MSI are nice and quiet and keep quite cool too. so I'd like to look at those if they'll fit.
Old July 7, 2013, 11:27 AM
JD JD is offline
You could likely cut a bit of the shroud on the Gigabyte card, but there's nothing to cut off on the MSI.
I'd agree and say you should just buy a shorter card.
If you really want the longer card though, cut out the HDD bays in the case.
Old July 7, 2013, 02:23 PM
Dzzope's Avatar
Measure the space and buy a card that fits? Whats the point in voiding your warranty instead of just buying one that fits?
Random quotes:
AKG: "So please don't piss on people and claim its raining. "
Soullessone21: "Their the only fat bitches I ever want in my wife :)"
DeeraxTheCoolNemo: "I never preSs CaPLoCK I just HiT my keyS so Hard ThEY Crit"
Old July 7, 2013, 07:57 PM
bissa's Avatar
because the 760 fits in my price range, and the gigabyte and MSI boards perform FAR better than the other offerings of that card.
Old July 8, 2013, 12:42 AM
Dzzope's Avatar
And if something else goes wrong you have no warranty to replace it.
Whats the point in a tiny increase in performance when you could be out of pocket if it dies?
Random quotes:
Old July 8, 2013, 12:54 AM
bissa's Avatar
yeah, for the most part, I'd much rather not mod the video card. I was more interested in what the ~ on the max video card length meant. also, as to cutting into the HDD cage, I can't really do that since I'm using 7 of the 8 bays and I'm planning on using all 8 eventually.
Old July 8, 2013, 02:28 AM
Dzzope's Avatar
So measure the exact length you have available and get a card that fits.
The ~ is to allow for discrepancies in the length due to slight variations case to case.
Also the MSI is only 267mm and every new GPU I have seen for quite some time has the power on the side, not the end.
Random quotes:
Old July 8, 2013, 02:46 AM
bissa's Avatar
Interesting. the reviews I was reading for it was saying it was 300mm long.
EDIT: Here it is
Fitting/pump Help homer98 Water Cooling 20 December 2, 2010 09:23 PM
[WTB] 1 SLOT SLI FITTING sinticfury Buy/Sell & Trade 4 December 31, 2009 03:39 PM
90 degree fitting Phobia Water Cooling 7 September 19, 2009 07:51 PM
[WTB] 3/8" T-fitting Cowboy Buy/Sell & Trade 0 June 17, 2009 10:31 AM
Fitting for top of micro-res V1 Sniper Water Cooling 6 December 6, 2008 04:12 PM
