-   -   2x GTX Titan's v 3x GTX 780's on 3x1080p res. (http://www.hardwarecanucks.com/forum/video-cards/61927-2x-gtx-titans-v-3x-gtx-780s-3x1080p-res.html)
BarisERYENTUR June 29, 2013 04:34 AM
Hi my name is Baris, im here to ask you guys about something that im not sure at.
here i will give you my system specs;
*i7 3930k OC'ed to 4.5Ghz +*
*Asus p9x79 Pro Motherboard*
*Corsair h100i Watercooler*
*Corsair 600T White case *
*Corsair AX1200i *
*16GB Corsair Platinum DDR3 2133 Mhz RAM (4x4) *
*2TB Western Digital Caviar Black HDD *
*240GB corsair Neutron series GTX SSD*
as you guys can tell theres something missing ''video card'' im going to be gaming in 3x @1080p monitors and i want a future proof video card(s) im planning on useing this system for a while witch one of these would be better for me;
2xGTX Titans or 3xGTX 780s
(my main concern is the 3gb frame buffer on gtx 780 s)
bliz June 29, 2013 06:10 AM
3x SLI does not work well...with your 3rd card expect 50% scaling or less :/, get 2 titans.Also less noise and power consumption.
Bond007 June 29, 2013 07:23 AM
You do start to loose scaling with every extra card, but I wouldn't say it doesn't work. A few points...there is no such thing as futureproofing, but if you do want to extend its useful life a bit of extra vram will assist with it. Personally I can't justify titan's price premium unless you have money that you have no use for and its burning a whole in your pocket. Rough pricing 2xtitan will be $2000, 3x780 will be $1800.
For me I would throw the idea of titan out the window (though I know others are willing to pay the extra will disagree). Honestly for 3x1080p I would go for 2x780 and try it out...if you find its not enough you could always throw a 3rd in down the road. If you are concerned more about the vram than the total gpu power another consideration would be 3x770 (there are 4gb versions) that you should be able to get for less than $500 each.
BarisERYENTUR June 29, 2013 07:32 AM
Thx for your time and answering :)
BarisERYENTUR June 29, 2013 08:07 AM
Thx for answering and giving nice info. i leaning more for titans cause people say in the future games will require more VRAM and 3 gb for 3x1080p screens is a little risky where as titans is not that much risk cause i know im not going to be having issues with vram and if i fell like i need more performance i can add another titan or just change it completly. :)
Bond007 June 29, 2013 08:44 AM
I understand where you are coming from with the concern. My issue with Titan is you essentially pay a 35-40% price premium over a 780 for 6gb vice 3gb of vram. You can see in the HWC review that some of the 780 are on par with Titan, for roughly 65% of the price.
If you haven't read it yet:
http://www.hardwarecanucks.com/forum...sc-review.html
I know its not an SLI review, but they are based on the same architecture, so scaling should be pretty much identical per card added. With that said you could have SLI 780 giving you approx 95% of the performance of SLI Titan and $700 in your pocket. Save that $700 and put it towards new graphics cards in a few years when the 3gb vram starts limiting you. Either way you will not be going wrong, but I personally would not be able to justify the added cost.
BarisERYENTUR June 29, 2013 10:37 AM
yea now i think i will be getting 780 s. witch version will be he best for a İCY themed pc (white/blue) Direct CUİİ,ACX SC,Twin Frozr,Reference...etc i dont care about that 5 fps diffrence looks is more important for me :) if you can help me find the best version for my system i will be very appreciated. Thx for your time :D
rjbarker June 29, 2013 08:17 PM
Tri SLi 680 / 780 for sure, will slightly out perform SLi titans for less $$$$$, obviously at this level power consumption is a non issure ;)
