-   -   Buying a new GPU (http://www.hardwarecanucks.com/forum/video-cards/61850-buying-new-gpu.html)
biagio1661 June 25, 2013 09:03 AM
Buying a new GPU
I want to upgrade my GTX560TI any suggestions? My budget is 450$ and I was thinking about the GTX770.
Bond007 June 25, 2013 09:28 AM
What resolution do you play at? The 770 would be the way to go if you want your budget mostly spent on GPU. I if you are at 1920x1080 resolution I would probably save some of the $ and go for the just released GTX760. That said you would not be going wrong with a 770.
biagio1661 June 25, 2013 10:57 AM
My resolution is 1920x1080 and my budget is only for a GPU so I dont mind spending it all.
Dzzope June 25, 2013 11:29 AM
770 would be my shout... should last 3 years at that res and then a whole re-build..
That said there is nothing wrong with saving quite a bit and going for the 760 / 670 when their prices drop a lil bit more from the 760 release.
The 760 is allot of performance for it's price.
Kindred1 July 1, 2013 05:12 PM
2 used gtx 670 like i did you can find for 225 everywhere now
shirazi_r July 1, 2013 06:35 PM
If he's only going to play at 1080p, there's no need for SLI 670s. That said, they do match the Titan for performance :bananafunky:
Dzzope July 1, 2013 10:03 PM
1 used 670 for that price then.. Great card.
The RealRollo July 2, 2013 04:43 AM
There's more to gaming than the fps reported by benchmarking.
I went from 680 SLi to one Titan, would not go back. Titan is smoother, feels more natural.
TedShackley July 2, 2013 06:47 AM
There are games in which they are definitely needed, but due to some crossfire hassles this time, maybe next time I'll go with a single card and play demanding games later on.
But now I'm at 2560x1600 so maybe that would'nt work as well with a single card either
great_big_abyss July 2, 2013 06:51 AM
If you're at2560x1600 then SLI 760's is definitely a great, cost effective option. Get more than the power of a titan, for half the price!
I ran SLI 660's and didn't really notice any of the SLI 'problems' which are said to exist. YMMV. I fully intend on going SLI 760's gain, vs buying a single 770/780.
