Old March 17, 2007, 12:35 PM
Default Getto Cooling relief for X Generation Cards
The Factory cooling solution on the Sapphire XTX1900X seems inadequate if you are going to game alot or OC the videocard. Some folks have ran extended ram heatsinks off the mosfets to put the generated heat up into the suction area of the fan shroud in an effort to increase cooling when you are running the boards hard.
Using a smoke stick I could track the airflow pattern and see the highest flow occured at the top 2 cm. of the shroud entrance with very low flow at bottom where the components rest.
I took a clear plastic box (3.5" screw box from Canadian Tire eh?) , same rough size as the width of the fan shroud. Using an X-acto blade, cut out both sides to the Fan shroud size,attached box to shroud using heat tape whereby basically extending the shroud 1.5 inches.
This simple getto mod put my Voltage regulators and Mosfets directly in the airflow tunnel, cooling all critical parts more then the stock system. As a side benfit, the fan is quieter at same rpm. Cheap,Fast, effective.
Try it out if your card is cooking all the time and Santa hasnt brought you an after market cooling solution yet and let me know if it helped your card out.
Old March 17, 2007, 12:42 PM
Babrbarossa's Avatar
ooooh neat! gotta post some pics!!!
psst, wanna see my binder?
Old April 12, 2007, 01:57 PM
Default 2nd Attempt
After running the cards hard on a 6 hour fear binge....The Getto Mod Rev. A didnt cut it. But for a 5 spot and a little more drawn on your 12 rail, I placed a fan at 90 degrees to the suction side of the factory turbine. The Fan measures 6 cm square, runs on 12 rail
" LAFAN 0.23amp. Model AD0612HB-A70GL" The Size is important as this unit fits between the cards perfectly, so no drilling,glueing or crap to get the job done.
As the Crossfire card does most of the work , it is the card I was looking to cool down. I enclosed a Screen Shot of the Mod and the Pre/Post temperature adjustment it made.
Old April 12, 2007, 09:10 PM
ebdoradz's Avatar
top card is getting fresh air but what about the bottum card???
Gigabyte GA-MA790XT-UD4P / AMD Phenom II x3 720BE @ x4/ Crucial Ballistic DDR3 / Sapphire 4830 5112mb / Corsair 620W PSU / 2*80GB Seagate
DFI LP nF4 Ultra-D / AMD Opteron 165 @ 2.7Ghz/ 2*1GB OCZ Gold GX XTC / Sapphire X1950XT / Fortron 450W PSU / 2*Maxtor 80Gb
ABIT KT7A-RAID / AMD Athlon XP 1800+ @ stock/ 2*256mb PC133/ Geforce 4 mx440 / 250W PSU / Maxtor 20GB
Old April 13, 2007, 01:25 AM
The Lower card rarely goes above Mother Board temperature while its in Crossfire Mode.
Old April 13, 2007, 01:56 PM
cdn_Madrach's Avatar
What are you using for a psu? I'm also running 1900's crossfire What are your system specs?
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
Silverstone Strider 1kw modular
4870x2
Ocz Vendetta 2
Top deck Tech Station
Samsung dvd
Old April 16, 2007, 08:38 PM
Epsilon 700 is the PSU , It made the Crossfire list when I started out looking for a new System.
what is a good brand for Radeon cards? Shadowmeph Video Cards 12 January 26, 2008 11:32 AM
Has anyone tried Xfire + Physics Card...3x pci-e cards. qwerty Video Cards 5 November 5, 2007 03:46 PM
how much vid cards affect 3dMark ragenrok Overclocking, Tweaking and Benchmarking 13 April 24, 2007 08:22 AM
HA! NVidia dx10 cards for agp? Babrbarossa Video Cards 7 March 1, 2007 06:36 AM
