Old May 28, 2013, 04:11 AM
GT7R's Avatar
Default GTX680 vs GTX590
Which would you take for the same (low) price?
Old May 28, 2013, 04:46 AM
The RealRollo's Avatar
680.
I'm re-thinking SLi after going from 680 SLi to Titan.
SLi is very good and as good as multi card gets, but it's not as smooth/responsive as single GPU.
Old May 28, 2013, 05:59 AM
Alpine's Avatar
680 680 680 680 680 680
Main system
|I7 3930K|Asus P9X79 WS|2X Evga GTX 690|Samsung 256G Pro|H100|Dominator Platinium 16GB 2133Mhz|AX1200|540 AIR|SP2500|Vengeance 2000|IBM PRO/1000 PT Quad Port|
Server system
|I7 3820|Asus P9X79|12G G.Skill 1600Mhz|Noctua NH-D14|Force 3 120GB|LSI megaRAID 9261 8|RAID5 5X 3TB|AX650|Fractal Design Arc Midi|IBM PRO/1000 PT Quad Port|
Old May 28, 2013, 07:10 AM
If you only care about raw performance... the 690... but there are so many positives of using a single 680 in comparison that you should consider it worth the loss of performance (and to top it off, you sometimes won't lose much due to the nature of SLI scaling and profiles).
Old May 28, 2013, 07:26 AM
GT7R's Avatar
I know the advantages/disadvantages of a single/dual GPU, the thing I've forgot to mention that it's gonna be used for computing. Not gaming.
Old May 28, 2013, 08:26 AM
"Quote This..."
590 all the way for parallel computing.
Old May 28, 2013, 05:34 PM
hero1's Avatar
If your needs are for computing then you might want to stick with AMD. Go and get the 7990 and be happy.
Old May 28, 2013, 05:52 PM
Dzzope's Avatar
He's talking about a 590 vs 680 for the same price not a $1000 card..
590 should yield better results although at the cost of noise, heat and power.. your choice, look at the numbers and decide yourself.
Old May 28, 2013, 06:24 PM
hero1's Avatar
Smile
I thought he was asking for that but someone mentioned a GTX 690 and I gave him something better for computer. However, since he's asking about GTX 590 and GTX 680, I'd say go get a GTX 680 for the same reason you mentioned above.
best gtx590 waterblock h0w3r Water Cooling 7 April 14, 2013 08:23 AM
[WTB] GTX580, or even GTX590 3.0charlie Buy/Sell & Trade 5 February 14, 2012 08:45 PM
2 or 3 gtx580 or 1 gtx590 JointTech Video Cards 8 December 7, 2011 08:34 PM
6870 x2 vs 6990 or gtx590 Pabz0r545 Video Cards 6 October 13, 2011 09:54 AM
Da big fat GTX590 dual-GF110 in FEB!!! [Nordic Hardware] Delavan Reviews & Articles from the Web 13 February 4, 2011 10:01 AM
