  #31 (permalink)
Old May 28, 2013, 03:46 PM
Do you guys think an AX760 can run 780 SLI or would it be cutting it too close? Since Max TDP is 250W each I should have enough headroom for rest of the system right? Probably going to go X87 with it too.
  #32 (permalink)
Old May 28, 2013, 03:58 PM
rjbarker's Avatar
I have the Evga Boost for my other Classified Board but never did use it (still int packaging), not all Biards by any stretch were having this problem, I went a year with Tri Sli 580's with no ill effects.
Firestrike Extreme: 21.452
MARK 11: 32.530
  #33 (permalink)
Old May 28, 2013, 04:22 PM
KaptCrunch's Avatar
will be ok on dual cards for 780's draw 24 amps per card with 63a available on 12v rail
  #34 (permalink)
Old May 28, 2013, 04:39 PM
hero1's Avatar
I will OC this card. I just read an article on anandtech where they were able to OC their card to crazy numbers. If I can obtain the same then I will run with a single card until I get the NZXT H630 then slap another one in there with waterblocks along with either the Seasonic or Corsair 1200 Platinum certified PSU.
I copied the following stuff directly from anandtech: AnandTech | NVIDIA GeForce GTX 780 Overclocking Results
  1. GeForce GTX 780 Overclocking
  2. Stock Overclocked
  3. Core Clock 863MHz 1063MHz
  4. Boost Clock 902MHz 1102MHz
  5. Max Boost Clock: 1006MHz 1228MHz
  6. Memory Clock 6GHz 7GHz
  7. Max Voltage 1.162v 1.2v
  #35 (permalink)
Old June 5, 2013, 10:16 AM
hero1's Avatar
Smile
So I took back my card and ordered the eVGA GTX 780 Hydro Copper version. I made the mistake of choosing ground shipping, unknowinlgy. It should be here by Friday. I will but that bad boy on and see what it can handle but I will for sure be adding another one before the end of this month or early July.
  #36 (permalink)
Old June 5, 2013, 11:11 AM
rjbarker's Avatar
I'm lost in this Thread....thought you already went SLi 780's .........btw..for SLi you certainly dont need a 1.2kW PSU...the only reason I have one is I occasionally grab a 3rd GPU for Benching fun (then inevitably sell it).
MARK 11: 32.530
  #37 (permalink)
Old June 5, 2013, 12:03 PM
hero1's Avatar
lol. I was going to get a second one but I thought about the cost of GPU water block and such and the price turned out to be the same for a Hydro Copper. So I decided to return my card and I ordered the eVGA GTX 780 Hydro Copper. I want to see how it handles the games and then will probably add another at the end of the month or early July!
And I know I don't need 1.2KW, my AX 850 is good enough for SLI/CF.
