Old May 25, 2013, 08:07 PM
Default Help, eyefinity + hdtv?
Just looking for a little advice, I currently have 2 computers side by side. One running 3 monitor eyefinity and the other is a basic htpc. What I am trying to do is get rid of the htpc and run 3 monitor eyefinity plus the tv as a separate extended display. What I am thinking is that I need another video card to run the tv alone on. Could anyone shed some light on this?
I'm currently running a 6870.
Old May 25, 2013, 09:00 PM
Dzzope's Avatar
Not sure it's possible on AMD
you can run surround (3 monitors) +1 on Nvidia though. I'll let someone else pipe up though as I have 0 experience with AMD surround set-up's.
Old May 26, 2013, 02:11 PM
Incase anyone else has this problem... turns out the 6xxx series cards don't support what I was trying to do. I solved it by getting a cheap 5450 and running the hdtv off of it.
Cheers,
Paul
Old May 26, 2013, 03:17 PM
Dzzope's Avatar
Ahh so you can run cards for 2 different feed.. cool to know. :)
calibrating my HDTV great_big_abyss Display Units 2 June 29, 2012 08:48 AM
Is Your New HDTV Watching You? LaughingCrow Off Topic 9 March 22, 2012 06:33 PM
HDTV Help joeperson Display Units 8 November 29, 2010 11:33 PM
Going from Laptop to HDTV Arinoth Troubleshooting 9 July 5, 2009 07:28 PM
How to hook up to HDTV? LegendofJubei Display Units 15 December 8, 2007 12:02 AM
