Old May 5, 2013, 02:23 PM
Default 7950 pcie x16 running @ x8
Hi,
I just got this new card and it is running at half the maximum speed of x16. I have it in the first slot in my motherboard and according to the manual it should automatically switch the the fastest speed, but it isn't. I am only running one card and there does not appear to be an option in the bios to manually switch the speed
I am aware that the difference in speed is negligible. I would like to figure out what is causing this though, does anyone have any ideas?
My motherboard is p8z77-v-lk
card is Newegg.ca - SAPPHIRE 100352-3L Radeon HD 7950 3GB 384-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
Old May 6, 2013, 09:08 AM
AlienIsGOD's Avatar
try running GPU Z and do the render test and see what it says in the bus interface box. It may be power management settings keeping it at a lower bus rate.
Gaming Rig (Gaming Cruncher): i5 3570K @ 4.2ghz, Sapphire RX 480 8GB, EVGA Z77 FTW Mobo, 8GB Mushkin Blackline DDR 3, Kingston SSDNOW V300 120GB | 1000GB Data, EVGA SuperNova 750w 80+ Gold, NZXT 810 Switch case
24/7 WCG Cruncher: i5 2400 @3.4ghz, Gigabyte HD Saphire 6870 1GB, AsRock Z68M/USB3 Mobo, 8GB HyperX DDR 3, 120GB HyperX Blue SSD | 1TB storage, CoolerMaster G750M 80+ Bronze, Thermaltake Soprano Snow Edition case
Old May 6, 2013, 12:54 PM
doesn't work :(
Old May 6, 2013, 02:34 PM
My understanding is the motherboard is "PCIE 3.0 READY" and sandy bridge processors only run PCIe 2.0.
Then I looked @ asus.com and read this: PCIe 3.0 speed is supported by Intel® 3rd generation Core™ processors.
Are you running a sandy bridge processor or an ivy bridge?
Old May 6, 2013, 02:47 PM
3.0charlie's Avatar
User manual, chapter 3 page 20: NB PCIe configuration.
Hydro-Quebec is salivating...
Old May 7, 2013, 05:52 AM
Hi all thanks for the replies, I am running IvyBridge my card reports pcie 3.0 x8 no pcie 3.0 x16. I have changed that bios setting nb pcie. I also have my card in the tops slot (blue) I hear about this blank video card or switch card needed in some motherboards?
Old May 7, 2013, 09:12 AM
lowfat's Avatar
That hasn't been needed in years. It should switch automatically. But make sure the card is under load while you are checking.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old May 23, 2013, 07:45 PM
any other possible fixes for this? could it be that the card is somehow damaged?
Old May 23, 2013, 09:53 PM
what render test, in GPUZ ??? I have 2nd newest version but don't see test
i7 2700k - 7950 3GB crossfire - 4GB 1866 CL8 - 1600p
HD 7950 vs GTX 670 overhauled101 Video Cards 9 January 6, 2013 07:09 PM
Running integrated graphics through PCIE card? clone63 Troubleshooting 5 February 3, 2010 07:41 AM
P5Q Pro PCIe running x8 not x16, why? Magnetar CPU's and Motherboards 7 June 28, 2009 01:23 AM
whats the difference between PCIe 2.0 x16 and pcie x16 Shadowmeph CPU's and Motherboards 5 February 16, 2009 12:07 PM
