Originally Posted by BigPhatPaulie I recently got a gtx titan and the card runs beautifully. The only issue is the stupidly high idle temps. The card never over heats but it idles around 50-65C  . Tried a driver reinstall and that didnt help. So im at a loss as to what it could be. (my last card randomly started to idle high as well) The card also seems to have some coil whine? |
Poor case air flow perhaps? Try to set a more aggressive fan curve, change the tim and see if that helps.
On air mine never idled anywhere near that high, and now on water it's <10 degrees above ambient while folding. This is on an open bench mind you.
