-   -   can gtx 580 run with 500w psu? (http://www.hardwarecanucks.com/forum/video-cards/60998-can-gtx-580-run-500w-psu.html)
schweppes May 1, 2013 03:33 PM
its a SilverStone Strider Plus ST50F-P 500W
I have read that 600w is recommended... but when I do voltage calculators, the system comes it under that number.
here is the rest of the build specs:
ASUS|P8Z77-I DELUXE/WD LGA1155
INTEL|CORE I5 3570K 3.4G 6M R
NOCTUA | NH-L9i R
4Gx2|CORSAIR CML8GX3M2A1866C9B
128G|OCZ VTX4
my other pc's ssd needs to be RMA'd, and is kaputz for now. would like to game on this with my gtx 580 in the mean time. is it possible on this psu? I can switch psu's, but I built mini-itx and not 100% sure it will fit with the size of the gpu as well
thanks friends
IRQ Conflict May 1, 2013 03:36 PM
If your overclocking that my put you into the 600W+ category.
enaberif May 1, 2013 03:38 PM
NOCTUA | NH-L9i R
128G|OCZ VTX4
thanks friends
Calculators are absolute crap! They are not reliable.
If you wish to keep your system stable and happy and have no issues look at a good 650w or higher.
Bond007 May 1, 2013 05:02 PM
It may, but I wouldn't go above a gtx 560ti on a 500w psu.
KaptCrunch May 1, 2013 05:55 PM
80Plus Bronze not really 34a on 12v rail
your card uses 19amps fine for single card
dual not going to do it
chubaka May 1, 2013 06:08 PM
at stock clocks you should be fine.
BrainEater May 1, 2013 06:34 PM
It will , depending on what else is running.
I had a 580 folding rig (Doing nothing but , no extra harddrives , no cpu load ) it was ~320 watts.
:thumb:
schweppes May 1, 2013 06:49 PM
All it would do is run bf3
Soultribunal May 2, 2013 09:42 AM
Should be good with no major OC on either CPU or GPU. Striders are generally solid, though the Sub 600W sometimes were FSP units.
-ST
