Old April 29, 2013, 06:50 AM
Default dedicated Physx card
I bought a 7870 myst a few weeks ago and I'm mostly happy with it. Except for the Physx performance - I tried playing borderlands 2 again last night with it and with the Physx stuff turned up it was really choppy and stuttering.
I remember reading a while back that you can plug in a dedicated NVidia card for Physx:
1st question: Anyone know how to do this and get it to work?
2nd question: What's the best card I can use for this. I'm running a MSI P67A-GD65/2500K with a HX620 PS. I'm not overclocking anything, so when everything is going at max I'm using ~300W. I have a Zotac 560 ti 448 but that will eat about 200W if I stick it in. So I'm looking to get a lower powered (6xx series) card to use for this. Any suggestions?
-Ds
Old April 29, 2013, 06:59 AM
great_big_abyss's Avatar
-Ds
That 560Ti 448 shouldn't eat that much power. If all it's doing is processing PhysX applications, then it will never run at 100%.
Good Luck getting all the drivers to play nice together. Should be fun!
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; Sapphire HD5870; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; ASUS GTX650Ti Boost; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
Old April 29, 2013, 08:13 AM
KaptCrunch's Avatar
can look here for ati /physX not sure of using an older ati card (non-cross fired) can dedicated like Nvidia does
Old April 29, 2013, 05:35 PM
I tried using an ATI card along with a dedicated NVidia card for PhysX. While it works for the most part other things start to screw up. Parts of the CCC software for the ATI card don't work correctly and it's insanely annoying. Overclocking the video card doesn't work exactly how you want it either. In fact I couldn't overclock either video card at all... it would OC in windows and shit the bed in games. I would highly suggest NOT combining the two different cards as you run into driver and software conflicts that will drive you crazy. Trust me on that one.
They are technically supposed to work together but it won't work well enough to justify. If you are serious about wanting dedicated PhysX I'd suggest changing over to Nvidia completely.
You are welcome to try it for yourself of course but I found the annoyance not worth the effort or the money.
My stuff for sale.
Mah Rig
Old May 1, 2013, 08:36 AM
I think i'll just dismiss this as a bad idea all around. I played BL2 again with no physx and it didnt look **Bad**
I was tempted to try it out on my basement game box just to see if i can get it to work before the summer heat kicks in but haven't gotten around to it as yet.
Interesting Dedicated PhysX Card Results Ruffcut Video Cards 0 August 22, 2012 01:18 PM
dedicated physx card Jaydu Video Cards 10 April 27, 2012 06:14 PM
Will my GTX 560 Ti SLI setup benefit from a dedicated PhysX card? Linus LinusTechTips Q&A 2 October 6, 2011 06:34 PM
Question regarding real world value of dedicated PhysX card Perineum Video Cards 7 May 10, 2011 06:43 PM
Dedicated Physx card with main ATI card? NineLives Video Cards 5 June 27, 2010 07:20 PM
