Old April 14, 2013, 10:30 AM
Charmster's Avatar
Default Radeon HD7850
Hi,
I am looking to upgrade my video card and was looking at the Radeon HD7850. I was looking at the HIS version but noticed it did not have the outputs I needed.
HIS Radeon HD 7850 IceQ X 2GB PCI-E w/ DVI, HDMI, Dual DP at Memory Express
I was wondering if there is a video card that you guys could recommend with similar specs, but can support VGA (Old second Monitor).
System Specs:
AMD Phenom II x4 965BE @3.6GHZ
CM 690 II Advanced
CM Hyper 212+
Corsair TX750W PSU
Gigabyte GA-890FXA-UD5
G.Skill Ripjaws F3-12800CL7-2GBRM - 4GB
EVGA GeForce GTX 650Ti Boost
Old April 14, 2013, 11:05 AM
just buy a 2$ DVI to VGA adapter and you still have HDMI!
Old April 14, 2013, 11:22 AM
Box containrs DVI-VGA Adapter
Old April 14, 2013, 12:18 PM
Brian's Avatar
My video card is an HIS model and I've tried contacting their support numerous times to no avail. I don't think they speak any language besides Chinese either. So if you have a problem with the card don't expect an exchange or any help from their customer support!
Old April 14, 2013, 12:33 PM
Bond007's Avatar
Just use an adapter as mentioned above.
Old April 16, 2013, 11:45 AM
Charmster's Avatar
Thanks for the responses. I also noticed that the video card supports only DVI-I. My monitor only supports DVI-D. Does that mean I would need two different adapters to connect both my monitors or can I use my DVI-D cable compatible with the DVI-I port of the graphics card?
System Specs:
CM 690 II Advanced
CM Hyper 212+
Corsair TX750W PSU
MSI HD7850 OC anygood? fyzek Video Cards 5 September 15, 2012 03:37 PM
Asus Radeon EAH6950 DCII, 2GB vs XFX Radeon HD6970, 2GB neo678123 Video Cards 3 January 20, 2012 11:44 AM
Heatsink that is compatible with Radeon 4870 and Radeon 5850? lsquare Video Cards 7 March 28, 2010 07:04 AM
[FS] AMD Phenom II X4 955, ATI Radeon 4850 512MB, ATI Radeon 4870 1GB icarus2 Buy/Sell & Trade 9 November 12, 2009 04:19 PM
