-   -   GPU headache (http://www.hardwarecanucks.com/forum/video-cards/60636-gpu-headache.html)
hero1 April 10, 2013 12:06 PM
GPU headache
Hey guys.
How's it going? I hope all is well. I have a dilemma here. I am looking to purchase a new GPU. I had 7970 in CF and they were nightmare after they stopped linking to each other and artifacting. So I stepped it up to the Titan but I just couldn't justify the price/performance. Now I don't have a card as I took back the DC2T due to the size that will probably limit me going 3-way SLI in September/October. So I was wondering whether to grab the Titan and SLI it (again the price/performance is crazy but I did get awesome frames no less than 55FPS on all games on Ultra settings with 2560x1440p). So I either get 2 of the following asap since the prices are going to go up (people think it will be just the lower end cards that use ddr3 but I have been told by a store manager that all cards will go up and not only due to ddr3 prices but because both Nvidia and AMD not releasing anything until Q1 2014).
My choices: 2 of each (I would love to have kept the DC2T and continue the red/black theme in my PC with ASUS parts)
EVGA GeForce GTX 680 SC SIGNATURE+ 1084MHZ 2048MB 6208MHZ GDDR5 SLI DVI DP PCI-E DX11 Video Card
EVGA GeForce GTX 680 FTW 1110MHZ 4GB 6.0GHZ GDDR5 SLI 2xDVI HDMI DP HDCP PCI-E DirectX 11 Video Card
EVGA GeForce GTX 680 FTW LE 1006MHZ 2GB 6.2GHZ GDDR5 SLI 2xDVI HDMI DP PCI-E DirectX 11 Video Card
MSI GeForce GTX 680 Twin Frozr III OC 1058MHZ 2GB GDDR5 2xDVI HDMI DP PCI-E DirectX 11 Video Card
ASUS GeForce GTX 680 DirectCU II 1006MHZ 4GB GDDR5 6GHZ 2xDVI HDMI DP PCI-E 3.0 Video Card
The reason I have so many eVGA cards is that I would like the cards to send the heat out of the case and not into the case and elevate the CPU temperature since I have aircooler now as opposed to H80i.
Thanks in advance and all inputs are appreciated.
Cheers
Hero1:bananafunky:
Slik April 10, 2013 12:19 PM
In my opinion,and if you can afford it,go for Titan SLI. Nothing available is better,or faster.
Soultribunal April 10, 2013 12:39 PM
Not true. If money isn't an issue Twin 690's would more than likely take out SLI Titan.
Microstutter not-withstanding.
-ST
Slik April 10, 2013 01:16 PM
-ST
Maybe so,but the Titans are less likely to have driver issues,and as you said,micro stutter notwithstanding.
bliz April 10, 2013 01:30 PM
Here we go again :haha: hmmm 690's.....
hero1 April 10, 2013 02:16 PM
Tough decision indeed. I was blown away by the Titan. I am wondering if it's better to just get the GTX 680s and SLI them now and add another later when I step up to the LGA 2011. I am looking to get rid of my ASUS Maximus V Formula along with the CPU which is 3570K. The last time I had the Titan on this platform it was great but having that in SLI with LGA 1155 is not a good thing, tons of bottleneck.
hero1 April 10, 2013 02:17 PM
Are you seeing any bottleneck on your setup because if you are not then I guess I might as well just upgrade the CPU and then grab another Titan. What do you think?
hero1 April 10, 2013 02:32 PM
Maybe I should wait for a week or so and see whether we have the benchmarks for the real 7990 from AMD. Here's an article showing them in CF courtesy of TH: http://www.tomshardware.com/news/Mal...reX,21931.html I got say, very tempting if they can price them lower than the GTX 690 and GTX Titan and have similar power draw and heat to the GTX 690 but time will tell.
Slik April 10, 2013 02:36 PM
No bottleneck with my config. No issues at all. Right now,my rig is running so smoothly, it's scary. Everything is stock,except my cpu at 4.2ghz. No need to go any higher. I have no problem recommending a similar set up.
hero1 April 10, 2013 02:48 PM
That's good to hear. I do programming on the side so I need the hexacores but I was dumb enough to grab the 3570K. I hope I get just get rid of my current setup: the motherboard, CPU and RAM and go to the 2011 platform.
And I think I will either end up with GTX Titan in SLI or simply the GTX 680s in 3-way SLI.
