Old April 12, 2013, 07:34 PM
bigFOIG's Avatar
Found the problem. The video card is stuck at 300MHz/150MHz. Gonna install the non-beta drivers and if that doesn't help, then I guess I will RMA it.
Old April 13, 2013, 05:59 AM
Bond007's Avatar
Even in games?
Old April 14, 2013, 02:24 AM
bigFOIG's Avatar
Yes, even in games. Also I realize that my E8400 CPU is underpowered for 1080p video. :(
Old April 14, 2013, 03:35 AM
KaptCrunch's Avatar
the 775 socket go quad with Q9650 If MB supports it
other is storage drivers and hardware my cause the jitters
Old April 14, 2013, 07:04 AM
Jim's Avatar
Jim Jim is offline
The 8400 is not necessarily a fail at all.Another approach as I've done with a early Pentium 4 is using a light weight linux distro (Puppy in this case) for an HTPC,works beautifully,1080p runs silky smooth all day long.Try it out,start with a live CD,then go daul boot so you can still game.But really in Windows an 8400 should handle video fine.
Old April 14, 2013, 09:36 AM
JD JD is offline
You could possibly try modifying/updating the BIOS on the card too. Depends how far you want to go to fix it.
Not at all. E8400 should do 1080p perfectly fine, even in pure software decoding. My E5200 had no issues.
Old April 14, 2013, 06:15 PM
bigFOIG's Avatar
Well, I've popped in a GTX 560Ti Hawk and while things are a little tiny bit better, 720p and 1080p is still not watchable.
When "trying" to watch 720p or higher, my CPU usage is stuck at 100% My computer pretty much froze for a while when I tried installed DirectX and watching a video at the same time. The CPU seems to be the problem right now...
I tried running League Of Legends at 2560x1440 on very low settings and I get 25 fps... I tried 1366x768 on very low and my fps is exactly the same.... There is no way a GTX 560 Ti can't play LoL with at least 100fps... My problem is not the video card right now evidently..... I am sure my drivers are installed and up to date...
Leaning towards the CPU right now even though I know it's a rare problem. I do have an E6600 laying around so I'll try that and see if things are better.
Old April 14, 2013, 06:52 PM
bigFOIG's Avatar
Okay I found the real real real problem. A quick look at CPU-Z shows that this CPU is actually.... wait for it... Pentium 4 640. LOL. Where the hell did my e8400 go....
  #19 (permalink)
Old April 14, 2013, 08:42 PM
dustin1706's Avatar
Had a similar issue with my laptop. Try this.
Right click on the youtube video > settings > local storage tab > move the slider to 0.
Hopefully that does it... Worth a shot anyways. Also, try a different browser.
MSI GT72 6QE-033US - 6700HQ, GTX980M, 1080p G-Sync IPS, 16GB DDR4, 1TB Evo 850 SSD, 256GB Toshiba SSD, 2TB Barracuda, BD-Rom/DVD-RW
  #20 (permalink)
Old April 15, 2013, 07:50 PM
JD JD is offline
how'd you manage that? We need a story!
strange radeon 7850 problem help!!! hossdaddy Video Cards 9 May 6, 2012 12:34 PM
Pricing on now released & available 7850 / 7850 cards terrybear Video Cards 11 March 22, 2012 04:13 PM
Coolit Eco - Should I, or shouldn't I? cul8erppl Water Cooling 4 May 31, 2010 08:15 PM
Denim and Computers...something that shouldn't be combined aviduser Cases 15 December 22, 2009 11:25 AM
Any reason I shouldn't get a NORCO RPC-4220? Perineum New Builds 0 August 11, 2009 12:19 AM
