Old April 8, 2013, 02:22 PM
Jim's Avatar
Jim Jim is offline
Default card for use with 60 hz monitor + bf3
Hi all,returning to pc gaming after two years of xbox.Question,shopping for an nVidia card for use with my 60 hz/fps limiting monitor for bf3,want to keep the frames at or as close to 60 fps as possible constantly(doesn't have to be ultra) high or medium/high settings are fine (even low on a pc is superior to xbox)even high/ultra @ 720p would rock my world,recommendations ?
Appreciate your input,thanks much.
Old April 8, 2013, 03:59 PM
Bond007's Avatar
For 720p go for a hd 7850 or gtx 650ti boost. Either will maintain above 60fps for that res at max settings. If you want it cheaper you could go to a gtx 650 ti or hd 7790 that you may have to turn a couple settings down to get 60 fps. And if money is tighter an hd 7770 would give you med- high settings at 720p.
Desktop: Arc Midi R2, Z77-D3H, 3770@4.1ghz with Zalman Optima Cooler, 4x4gb ram, EVGA GTX 1070 Ti SC, Bitfenix Fury 750w, WD Black 1TB, MX500 500gb
Away from home: Lenovo Legion Y530, 16gb, i7 8750H, GTX1050Ti
Old April 8, 2013, 05:20 PM
Jim's Avatar
Jim Jim is offline
Awesome,just what I needed to know,leaning to nVidia,don't like Catalyst much,it'll be light years ahead of the console.
Old April 8, 2013, 06:58 PM
JD JD is offline
Yup, 650TI is what you want. You don't even need the "boost" edition if you want to save some coin.
My friend paired the 650Ti up with a Core 2 Quad and it runs BF3 like a champ on his 720p TV.
Make sure you have 6-8GB of RAM though, 4GB isn't quite enough for BF3 IMO.
Old April 8, 2013, 07:31 PM
Jim's Avatar
Jim Jim is offline
nice,thanks,think this'll do the trick Zotac GeForce GTX 650 Ti 941MHZ 1GB 5.4GHZ GDDR5 2xDVI Mini-HDMI HDCP PCI-E DirectX 11 Video Card
Old April 9, 2013, 03:49 AM
7870xt will be the best you can get,it's cheap and even more powerful than a 660ti.
anyway of you search you can find them for 230 american dollars,and this will give you more than 60 fps in BF3 ultra,probably and better take something a bit more powerful that you won't regret i think.
of course if you play medium - high settings,650ti is more than enough.
Old April 9, 2013, 05:45 AM
Jim's Avatar
Jim Jim is offline
7870 xt good point,trouble is ATI drivers with their overscan/underscan issues (black borders) in windows and games,does that go away ?
Old April 9, 2013, 11:39 AM
Oh yeah,now drivers are pretty good,maybe they crash a bit more but they are overall almost as good as nvidia drivers these days,i think...Some old drivers were really bad though but don't worry,now it's as if you were playing with a nvidia card ^^
Old April 9, 2013, 11:44 AM
Jim's Avatar
Jim Jim is offline
hey nice!,thanks man,still goin around in circles reading to much,need to pull the trigger
Old April 10, 2013, 06:52 AM
Save up and get a 1080p monitor, 3 years ago I got a 24"er for $200 on sale, still using it today
i7 2700k - 7950 3GB crossfire - 4GB 1866 CL8 - 1600p
Will video card kill a monitor? Slik Video Cards 15 February 22, 2011 08:19 AM
Thinking of getting a new monitor after I get my new gfx card grifter11 Display Units 3 November 1, 2010 12:01 AM
Monitor, motherboard or gfx card going bad? Jaeger_CDN Troubleshooting 13 March 26, 2010 06:04 PM
Good card for a 23" monitor Ghiness Video Cards 1 January 28, 2010 04:30 PM
Second card for second monitor NyteOwl Video Cards 1 October 5, 2008 08:28 PM
