Old April 8, 2013, 09:37 AM
clg clg is offline
Default gtx660i's in sli, weighing options
I've currently got a pair of 660ti's and I'm considering my options for the future. I'm curious as to how well they'll perform powering a 1440 or potentially even a 1600p monitor. Currently I'm mostly playing bf3 and will likely be picking up bf4 when it launches. I've only got them powering dual 1080p's now (so 1 whilst gaming) and it's definitely up to par and then some considering they're only 60hz, but I don't want to take too big of a hit if I upsize my monitor substantially.
Old April 8, 2013, 10:06 AM
ZZLEE's Avatar
How many GB of memory do the 660 TI have ?
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old April 8, 2013, 11:07 AM
clg clg is offline
2gb cards
Old April 8, 2013, 11:13 AM
I'm confused. What resolution do you actually want to run these in? 1600p resolution?
1440 is a 16:10 resolution.
At a 1440 resolution a single 660ti should MORE than suffice.
Old April 8, 2013, 11:44 AM
clg clg is offline
A single 660ti was falling short with my 24" 1080p, not sure how it would sufficiently run a monitor that much larger :/
Old April 8, 2013, 12:35 PM
Bond007's Avatar
What is the rest of your system?
Old April 8, 2013, 12:45 PM
I run a gtx 560ti on my 24" monitor and while I have to turn some settings down I don't see much of an issue.
Old April 8, 2013, 01:49 PM
clg clg is offline
3570k oc'd to 4.2
750w psu
8gb corsair vengeance ram
Only when I picked up the second gpu was I able to run every setting maxed and not have any fps drops in 64 man multiplayer, and I want to keep it that way.
Old April 8, 2013, 02:09 PM
ZZLEE's Avatar
You probably Looking Fore a 4 GB card. The higher the restitution the more gigs and better cards fore higher frame rates.
Nividia will refresh soon but some thing close to the preference off a Titan is what you seem to want. Two of them is Killer.
Old April 8, 2013, 04:07 PM
Bond007's Avatar
You should be fine on your current cards. 2gb VRAM should be fine (may have to turn some AA off in a couple titles).
Best value of these options? Dzzope Power Supplies 9 March 24, 2013 11:15 AM
Other options than WD ? botat29 Storage 18 February 24, 2012 12:49 AM
Options... kongfoo911 Water Cooling 2 May 13, 2011 07:35 PM
RMA: What are my options? Gaston Troubleshooting 7 March 22, 2010 12:34 AM
ISP options Cheator Networking 21 August 25, 2008 10:03 AM
