Old April 9, 2013, 10:44 AM
Manufacturer Rep
Although I always recommend 3GB+ for triple display or resolutions higher than 1440p, 2GB cards are by no means incapable of running current games in high resolutions as long as you're willing to compromise just a little. Some games are more memory intensive than others, but on your system I'd think you should be fine as long as you use FXAA or FXAA + 2X MSAA instead of 4X/8X MSAA, which hogs a ton of memory. When I tested a pair of GTX 660 Ti GC 2GB vs. a pair of GTX 660 Ti GC 3GB, the 3GB cards didn't start really leaving the others behind until I started maxing out MSAA.
Best value of these options? Dzzope Power Supplies 9 March 24, 2013 11:15 AM
Other options than WD ? botat29 Storage 18 February 23, 2012 11:49 PM
Options... kongfoo911 Water Cooling 2 May 13, 2011 07:35 PM
RMA: What are my options? Gaston Troubleshooting 7 March 22, 2010 12:34 AM
ISP options Cheator Networking 21 August 25, 2008 10:03 AM
