Old April 2, 2013, 05:22 PM
Trial Member
Default ASUS Radeon 7850 not booting well with Gigabyte X58
Recently replaced my old Sapphire Radeon 4850 with a new ASUS Radeon 7850 (DC2-2GD5-V2) and havenít been able to boot up with it in Windows 7...I should clarify: Technically I can boot up fine with it, but following Window's 7800 drivers update, all subsequent boots yield the same problem: No video, can't get past POST error code 2b (Video-card related according to manual)
Iíve tried a number of things, but no luck so far ( i.e. inserting it in a different PCIEx16 slot, double-checking the wattage ) The 4850 still works fine if I re-insert it.
Looking for any suggestions from anyone whoís had a similar plight, so I hopefully donít have to return it ( been itching to play Bioshock Infinite :] ) The only thing I think that could be causing the problem is my motherboard, it conforms to PCI Express 2.0, while the video card is rated as 3 (though Iíve read on other forums that shouldnít be a problem ?)
My specs:
Motherboard: Gigabyte X58 GA-EX58UD5 3-way Crossfire ( BIOS: vF13 )
CPU: Intel i7-920 2.66GHz 8M LGA
Power Supply: Kingwin 680 Watt
OS: Windows 7 64-bit ( 6gb RAM )
Thanks!
Joey
Old April 2, 2013, 05:40 PM
stephengillon's Avatar
can you boot to safe mode no problem?
your probably having older driver conflicts
supaflyx3's Avatar
So after installing the drivers it won't post anymore? Do you have access to another system that you can test the card in?
gtx 660 vs Radeon HD 7850 hatchi Video Cards 12 January 16, 2013 06:48 PM
Gtx 560ti 2gb vs Radeon HD 7850 2gb xaeleep Video Cards 3 August 5, 2012 11:32 PM
CPU and Radeon HD 7850 easy guide Chasingu HardwareCanucks F@H Team 3 July 7, 2012 10:15 PM
strange radeon 7850 problem help!!! hossdaddy Video Cards 9 May 6, 2012 12:34 PM
