-   -   Sapphire HD6950 making clicking noise (http://www.hardwarecanucks.com/forum/video-cards/60453-sapphire-hd6950-making-clicking-noise.html)
Tech686239 March 29, 2013 06:23 PM
Hello HWC,
My video card seems to be making a weird clicking noise. I took it out and blew out all the dust. I put it back in and it still seems to be making the noise. My next guess is that a fan is dying. I checked it while it was running and it looks to be fine. I also check to make sure there were no wires that the blades might be hitting. Everything looks good.
any ideas?
Thanks!
Tech
YukonTrooper March 29, 2013 06:34 PM
Well, if it's indeed a clicking noise and you're sure it's coming from the video card then it has to be the fan; it's the only moving mechanical part.
Stop the fan with your finger while it's running and you'll know right away.
Tech686239 March 29, 2013 06:36 PM
Stop the fan with you're finger while it's running and you'll know right away.
Yea, I am pretty comfortable that it's the video card. I removed it from the PC and the noise stopped.
I am thinking about an aftermarket cooler maybe. Not sure tho
Bond007 March 29, 2013 06:45 PM
Is it actually making contact with plastic causin the clicking, or some other noise?
Tech686239 March 29, 2013 06:46 PM
I can't see it hitting anything... I think the fan is just failing
Tech686239 March 30, 2013 06:26 AM
Anybody know of a good aftermarket cooler that i could put on this card?
NSdeadly1 March 30, 2013 09:57 AM
Check these out VGA Cooling ARCTIC I also found it very interesting they have them listed as compatible with the HD 8XXX series.
YukonTrooper March 30, 2013 10:32 AM
You'll be spending about $50 before taxes and shipping for a new heat sink. Considering it's an older card, it might make more financial sense to sell the card and buy a newer one.
You could also put up a "looking for" ad in the trading forum. Someone might have a stock heat-sink kicking around.
Tech686239 March 30, 2013 11:41 AM
Yea i have considered buying a new card. Not really sure what to get and don't really want to spend a ton of money.
Tech686239 March 30, 2013 05:07 PM
The 650 Ti would be a downgrade from the 6950 eh?
