Old March 30, 2013, 05:27 PM
great_big_abyss's Avatar
Originally Posted by Tech686239 View Post
The 650 Ti would be a downgrade from the 6950 eh?
I don't think so. Quite a bit more powerful. Maybe not worth the money to upgrade. But, if your fan is dead anyways, it would be a good choice.
Old March 30, 2013, 05:36 PM
Tech686239's Avatar
how are your 660's?
"Being fat isn't easy. Try putting on socks."
Old March 30, 2013, 06:36 PM
Bond007's Avatar
Should be able to find someone that watercooled and is willing to sell the air cooler.
Desktop: Arc Midi R2, Z77-D3H, 3770@4.1ghz with Zalman Optima Cooler, 4x4gb ram, EVGA GTX 1070 Ti SC, Bitfenix Fury 750w, WD Black 1TB, Intel 530 120GB
Old March 30, 2013, 07:36 PM
how are your 660's?
Incredibly quiet. Seriously. the fans stay at 10-30% during most use. I tried upping the speed manually, just to see what they would sound like, and you can't hear them at all under 60%. At full bore, they're just a dull whisper. I was floored when I heard how quiet they are. They're the quietest cards I've ever owned. And there's two of them!
Anyway, they perform great. Haven't noticed any microstuttering or any other bugs. I'm running BF3 at Ultra with full anti-aliasing, and I'm getting anywhere from 80-100fps.
One card could easily run BF3 on Ultra, albeit with AA turned low.
Old March 30, 2013, 07:38 PM
Tech686239's Avatar
Could you link what cards you have... i would like to take a look on NCIX
Old March 30, 2013, 07:47 PM
ASUS GeForce GTX 660 OC DirectCU 1020MHZ 2GB 6.0GHZ GDDR5 2xDVI HDMI DisplayPort PCI-E Video Card
I had a GTX680 before these two, and I must say, I don't regret changing over one bit. These two cards are quieter than the one 680 with aftermarket heatsink.
Old March 30, 2013, 08:20 PM
Tech686239's Avatar
They are currently 200 bucks @ ncix. Now i just have to convince my wife
Old April 9, 2013, 04:28 AM
Tech686239's Avatar
@great_big_abyss: I am using 3 24" monitor on my gaming rig. 2 DVI and one with an active displayport adapter. I see that ASUS 660 OC DirectCU are onsale right now for 184 after sale and rebate. Do you think this card can handle it? If i did get this card i would plan to add a second later. Or should i wait for the next generation of cards?
Seagate 5400.6 320GB 2.5" Clicking Noise -- Turns out it's not the hard drive! :s m0pelley99 Storage 5 February 7, 2012 07:20 PM
Harddrive Is making a weird clicking noise andynerd Troubleshooting 3 November 11, 2010 08:23 PM
HDD Making Noise? geokilla Storage 8 July 27, 2010 04:22 PM
clicking noise on my Seagate Dashock Storage 14 January 1, 2010 09:30 PM
gtx 275 is making noise... (not the fan) lexmark1 Video Cards 19 May 20, 2009 04:22 AM
