Old March 14, 2013, 02:16 PM
Default Replace GTX680 with 7970?
I am considering selling my Galaxy Geforce GTX680 and moving to a ATi 7970 as I play all my games at 2560x1440 resolution, would I notice an improvement in both IQ and FPS at his resolution?
Did you try turning it off and on again?
Old March 14, 2013, 02:33 PM
great_big_abyss's Avatar
Probably not much. Which version of 680 do you have?
Old March 14, 2013, 02:57 PM
Galaxy 2GB 68NPH6DV5ZGX
Old March 14, 2013, 04:19 PM
Bond007's Avatar
I would say its not worth the time or effort.
Desktop: Arc Midi R2, Z77-D3H, 3770@4.1ghz with Zalman Optima Cooler, 4x4gb ram, EVGA GTX 1070 Ti SC, Bitfenix Fury 750w, WD Black 1TB, Intel 530 120GB
Old March 15, 2013, 06:29 AM
Depends on games etc, 7970 overall is slightly more powerfull or slightly weaker depending of course on game, settings used, clock speeds etc. if it was a +/- scale out of 100, 7970 IMHO would be a 95 680 a 93(unless I wanted to be real biased as I hate Nvidia as a whole with a passion)
Either way, they are both super capable, very fast/powerfull cards, the 680 has an edge in power use, 7970 has an edge with higher resolutions(powering multi-monitor)
Old March 15, 2013, 06:33 AM
Do you find yourself running out of frame buffer? If so, I would say that would be the only reason to switch. That, and you wanting to switch. As far as the gpu chip itself, I'd say they're pretty evenly matched when it comes to framerates... Certainly not worth the loss you'd get by selling your gpu and buying a brand new 7970.
I would argue that the only way a switch would make sense would be if you were to find a used 7970 and trade it for your GTX680. That would be your best bet, and surely not that hard to find someone willing to make a trade.
Old March 15, 2013, 10:34 AM
I haven't tried a 680 yet but I have no complaints at all with my 7970!
You should have no issues at all though swapping (straight up trade 1for1) with someone though!
Comp1 (Mine) : ASUS P9X79 LE, 3960X, 16GB Corsair Vengence 1333, PNY 770 4GB, OCZ Vertex3 240GB, OCZ Vertex3 480GB, 600GB VelociRaptor, Corsair 1000HX, Cool Master Cosmos 2
Old March 15, 2013, 12:32 PM
Thanks for the feedback guys, it seems that the message is clear, keep the GTX 680 as there is a minor difference between the two at best.
Old March 16, 2013, 07:43 AM
http://www.hardwarecanucks.com/forum...hd-7970-a.html
This seems like a good deal... You should be able to get at least that much, if not more for your 680.
Old March 16, 2013, 09:43 AM
Dzzope's Avatar
And a few free games to boot.
If you can do it without spending anything or better make on the deal, by the free games or buying a second hand 7970 then go for it.
GTX680 Red Screen of Pi$$ing Me The Heck Off .Head_Shot. Troubleshooting 20 July 29, 2012 05:05 PM
3930K Dual GTX680 DCII TOP Build Almost Done SonnyM5 New Builds 7 July 25, 2012 09:55 PM
GTX680 Cooler fit GT7R Video Cards 1 July 5, 2012 05:54 PM
Completed MM Ascension Socket2011 Quad SLI GTX680 Build MattC Case Mods, Worklog & Gallery 16 May 10, 2012 07:10 PM
gtx680 opinions shelfelf New Builds 7 April 21, 2012 12:07 AM
