Old March 8, 2013, 02:21 PM
Default First 2560*1440 monitor, is video card the only thing that needs upgrade?
Hello all. I game as a hobby, nothing too serious. I've decided to upgrade my trusty aging Dell 2407 for a U2713HM (its on sale today @580, and I've seen one in action and loved it), meaning I'm adding I think 78% more pixels to process when gaming. My system isn't that old, but Im guessing I'll need to upgrade some of it to keep playing games at good settings with decent FPS.
My first question is general: am I correct to assume that the increase in resolution will tax pretty much only the video card more, while the CPU and the RAM should perform generally as well after such a change in resolution?
My second question is more subjective. My system isn't even 2 years old yet, but I haven't been keeping up with desktop hardware developments much during that time. Would you care to tell me if it would efficient to just upgrade my video card for such a new monitor? Or is it already time to think about upgrading everything because a new card would be bottlenecked by the rest? Thank you.
This is my current system;
Gigabyte Z68X-UD3H-B3 ATX LGA1155 Z68 DDR3 1PCI-E16 3PCI-E1 2PCI HDMI SLI SATA3 USB3.0 Motherboard
Intel Core i5 2500K Quad Core Unlocked Processor LGA1155 3.3GHZ Sandy Bridge 6MB
Coolermaster Hyper 212 Plus Direct Touch 4 Heatpipe Heatsink AM2 AM3 LGA1366 LGA1155 LGA1156 120MM
G.SKILL Ripjaws X F3-12800CL9D-8GBXL 8GB 2X4GB DDR3-1600 CL9-9-9-24 Memory
Crucial M4 SSD Micron C400 64GB 2.5IN Solid State Disk Flash Drive SATA3 6Gbps
Sapphire Radeon HD 6950 2GB GDDR5 PCI-E 2XDVI HDMI DisplayPort Video Card
Old March 8, 2013, 02:32 PM
GT7R's Avatar
Just try and see how your current card performs for you needs... then decide whether you actually need to... if yes then something like a 7950/GTX670will be a nice upgrade. Other than that your system is fine.
Old March 8, 2013, 02:43 PM
Thanks, and you're probably right. I'm not sure how extra taxing this increase in new resolution can be, so I'm probably better off testing first.
Old March 8, 2013, 02:56 PM
Keep in mind that with higher pixel density there is less need for AA which can help offset some of increase in GPU requirement.
Old March 8, 2013, 03:09 PM
great_big_abyss's Avatar
As said before, you may find your 6950 to be perfectly acceptable. It is still, after all, a very potent card. If however, you find that framerates are slowing down at your ideal quality settings, then yes, it will be your video card that needs changing. Your CPU is still perfectly current.
Old March 8, 2013, 03:25 PM
geokilla's Avatar
Have you overclocked? If not, do it.
I wanted to buy that monitor, but it doesn't fit on my desk, unless I remove a portion of the desk :(
Old March 8, 2013, 03:49 PM
Perfect, thats exactly what I wanted to know.
And yes, I have slightly OC'd all my hardware. I havent tried pushing the 6950 further than what the super safe CCC overclock allows tho. I think its only 5%. I could try a real overclock, just never needed to yet.
Old March 8, 2013, 04:33 PM
Bond007's Avatar
You will be fine with your CPU and ram. Try your current gpu with aa off and maybe a setting or two turned down. If that's not enough for you then your in for a gpu upgrade(or xfire your 6950 if you can find a used one cheap).
Old March 9, 2013, 12:28 AM
rjbarker's Avatar
I took the plunge to 2560 x 1440 Res from 1920 x 1200 quite a few yrs ago, you'll find a single GPU is going to take a real hit..big time when jumping up that many pixels, personally I have gone multi GPU's ever since (as in SLi) and with today's DX11 titles I still have to "tweak down" to maintain 60 FPS throughout.
Firestrike Extreme: 21.452
MARK 11: 32.530
Old March 9, 2013, 10:15 AM
"Quote This..."
Give it a shot with the old card first. may be just fine. My 590 only has 1.5gb of ram and that is not enough to enable AA at 2560*1440, your 2gb of ram should be.
Good Cheap card for 3 X 27" WQHD 2560 x 1440 JustinZ Video Cards 1 September 1, 2012 01:41 AM
Keep getting mixed responses - $300 7950 or $400 GTX 670 for gaming at 2560 X 1440. Trax416 Video Cards 22 August 19, 2012 05:38 AM
GTX 480 SLi Benches 2560 x 1440 rjbarker Overclocking, Tweaking and Benchmarking 0 November 20, 2010 06:08 PM
U2711 2560 x 1440 Text Unreadable Adjustemnts Made. rjbarker Display Units 10 November 16, 2010 08:06 PM
