Old March 6, 2013, 06:03 PM
BVickery's Avatar
Default 7870 XT vs 7950
Ok, within a month i will be upgrading my GTX 260.
Now the question is which of the two. I like the AMD this go around, the question is which one?
The two cards I am looking at are:
Sapphire 100352-2L Radeon HD 7950
$290 but $270 after rebate
or
Sapphire 100354XTL Radeon 7870 XT $260 but $235 after rebate
I am not sure if the $30 premium worth it. I tried to look for Skye's review on such a thing (I really trust his reviews). Any thoughts between the two?
Old March 6, 2013, 06:28 PM
Killswitch's Avatar
Depends. Do you plan on upgrading your monitor? I see in your specs you have a 20". The 7870 would probably suit you fine, but I'd go with the 7950 otherwise.
Old March 6, 2013, 06:37 PM
BVickery's Avatar
Oh, forgot to add.
I currently have a 22" Asus 1920x1080. Upgraded my specs.
Old March 6, 2013, 08:40 PM
Coach's Avatar
what about a 7870 based off of Tahiti? Powercolor Radeon PCS+ HD7870 Tahiti LE EZ EDITION2GB GDDR5 DVI HDMI Mini DPX2 PCI-E2.1 Video Card
Old March 6, 2013, 08:48 PM
IRQ Conflict's Avatar
They all out of Myst Editions? Or is that what this is?
Edit: Here is a review of the Myst Ed.
Edit#2: Apparently this is the EZ Edition. Same as Myst only with a crappier cooling solution.
Old March 6, 2013, 09:10 PM
BVickery's Avatar
Originally Posted by Phill View Post
The 7870 is the Sapphire based version of the PowerColor Myst edition. The 7870 XT is the 7870 based off of the Tahiti core.
Old March 7, 2013, 04:59 AM
Bond007's Avatar
Because its only $25 difference after MIR, I would go to the 7950. The XT/MYST/whatever else you want to call it have been cheaper than that (they can be a great bang for buck if they are cheaper IMO). There isn't a massive difference in performance, but the 7950 (from what I have read) run cooler and use less power, while being a bit faster. You could also consider a 660Ti in that price bracket (if you want to stick on the Nvidia side of the fence).
Old March 7, 2013, 09:52 AM
25 bucks for a 7950? No brainer for me, i'd got with the 7950. Memory bandwidth is going to be way more on the 7950 (+128 bit difference) and a bunch more stream processors for 25 bucks!
And is that a crysis cupon i see??? 169.99 vs 149.99 value gift coupon means that (if you use all of the coupon's value) you're paying 5 bucks for a fundamentally better card (not just tweaked clocks).
Old March 7, 2013, 12:40 PM
BVickery's Avatar
I usually try to keep the game coupons out of it. But thanks for the feedback. Will try and pick up the 7950 when I finish getting my money.
HD 7950 vs GTX 670 overhauled101 Video Cards 9 January 6, 2013 07:09 PM
[WTB] GTX 580 or 7950 schwartz Buy/Sell & Trade 1 April 30, 2012 03:14 PM
Which 7950 should i get? Mark Romero Video Cards 18 March 9, 2012 04:02 PM
7950 GT for 129$ ebdoradz Video Cards 1 March 8, 2008 03:00 PM
