Old March 6, 2013, 09:47 AM
Yeah, two 7970 would result in horrible nightmares
Old March 6, 2013, 10:19 AM
IRQ Conflict's Avatar
Yeah, my Matrix Platinum is slightly louder then the Lightening. I never hear it unless I manually tweak the fan. I sit about five feet away from it at all times. ~44db @12" is nothing.
Old March 6, 2013, 11:13 AM
GT7R's Avatar
My card is pretty audible under load @1200mhz and maxes 63c under load. 2 would be too much. As well as I can't stand the micro stutter of CF.
Old March 6, 2013, 11:30 AM
Coach's Avatar
It may not be the popular point of view but if I were you I would pony up and get the Titan. You are saying that right now you need a better card and that it needs to be ONE card. As well you are saying it shan't be dual gpu. There is no choice other than Titan.
I have played with SLI for years and now prefer only one gpu. I have been thinking about a Titan for myself but I do not think I will get one. I plan on waiting till Maxwell is released. Chances are then I will be able to buy Titan performance for less than half the cost... I guess my 680 Lightning will have to do.
Old March 6, 2013, 11:34 AM
GT7R's Avatar
Been thinking the same thing. Just wondered whether micro stutter was improved with the kepler cards as I've got no 1st hand experience with them.
Old March 6, 2013, 11:39 AM
r0bc's Avatar
I just wish the GTX 690 had a larger frame buffer
Old March 6, 2013, 11:42 AM
Coach's Avatar
Micro stutter is the same as Frame Latency correct? I would study charts like these. If you want to look at more of such charts then read SKY's Titan Review. NVIDIA GeForce GTX TITAN 6GB Performance Review
Old March 6, 2013, 12:06 PM
Get the titan imo. According to the data, it is the "smoothest" card out there. Check out HWC review.
I'd only go multi GPU if you have a real passion for tinkering. If you have a real passion for gaming always get the best single card you can. It seems all multi GPU setups increase frame latency a tad.
  #19 (permalink)
Old March 7, 2013, 04:19 AM
Dzzope's Avatar
If you want it to be really smooth then the titan is the one to go for. It is less power but much more smooth.
  #20 (permalink)
Old March 7, 2013, 05:01 AM
GT7R's Avatar
After some research and your input, Titan it is. Thanks guys
Where is the Titan? Slik Video Cards 1 February 19, 2013 06:48 AM
GeForce Titan GT7R Rumor Mill 67 February 11, 2013 02:45 AM
Titan Quest key Lamb Off Topic 5 December 9, 2012 05:37 PM
[FS] Titan Fenrir X'mas ed - $30 xhrrcollector Buy/Sell & Trade 2 February 11, 2011 09:15 PM
[FS] Titan Fenrir Iphikratous Buy/Sell & Trade 5 December 15, 2010 10:02 PM
