Old February 20, 2013, 10:01 AM
GT7R's Avatar
Default Mini DP to DVI problem
My videocard has 2x Single link DVI and 4x Mini DisplayPorts. I'm using an active Mini DP to DVI adapter and the max resolution I'm able to set on my U2711 is 1600x1200.
Any clues...?
Thanks in advance!
Old February 20, 2013, 10:24 AM
SugarJ's Avatar
Sounds like your adapter. Why not use the dual link DVI plug? (one is single, the other is dual according to my research).
Old February 20, 2013, 10:25 AM
GT7R's Avatar
It says both are single link ones MSI Global ? Graphics Card - R7970 Lightning
Old February 20, 2013, 10:27 AM
SugarJ's Avatar
I beg your pardon, I was mistaken. Which active adapter are you using?
Edit: assumed you are using an active adapter, which might not be the case.
I'd use a miniDP to DP cable rather than a miniDP to DVI cable. Startech 10FT Mini DisplayPort to DisplayPort Adapter Cable - M/M
Old February 20, 2013, 10:28 AM
GT7R's Avatar
The one I've received with my previous 6990. Says it's active.
Edit: Just ordered one. Hope that adapter was all the problem. Thought there was a tweak/fix for windows or I've needed to install an additional driver of some sort. Thanks
could this be a game problem or a video driver problem? Shadowmeph Troubleshooting 4 December 17, 2010 06:01 AM
Two New Lian Li Mini-Q Series Mini-ITX chassis FiXT Press Releases & Tech News 1 September 9, 2010 12:05 PM
ZOTAC Revolutionizes ION With Intel CULV-Powered Mini-PC and Mini-ITX Platforms FiXT Press Releases & Tech News 5 August 27, 2010 01:48 PM
Lian Li Launches PC-Q08A/B/R Mini Tower Chassis for Mini-ITX and Mini-DTX FiXT Press Releases & Tech News 1 April 29, 2010 09:17 PM
Completed My Mini HTPC Build (bedroom PC) Mini box M350 CoolHandL Case Mods, Worklog & Gallery 4 April 26, 2010 07:25 PM
