  #21 (permalink)
Old February 20, 2013, 05:46 AM
Arinoth's Avatar
I'm still not overly impressed with the driver support and what have you from AMD, find nVidia still has the better well rounded product if you factor in their far superior drivers.
  #22 (permalink)
Old February 20, 2013, 10:22 AM
JayDeeHobbit's Avatar
Your suggestions have given me some food for thought for sure.
I have decided on this card:
Galaxy GeForce GTX 670 GC 1006MHZ 2GB 3004MHZ GDDR5 Dual Fan SLI 2xDVI HDMI DP PCI-E DX11 Video Card
At $350 it is a great price and offers all the advantages of a non-reference design for cooling and noise.
While I can OC a 480 to get better perfomance levels than the 670 I think for 1920x1200 I have concluded the 670 will fit the bill for me.
Thanks for all the input guys!
"Try looking into that place where you dare not look!
You'll find me there, staring out at you!" - Frank Herbert
  #23 (permalink)
Old February 20, 2013, 10:25 AM
SugarJ's Avatar
That will drive 1920x1200 no problem, should be max details and max AA capable at good framerates.
  #24 (permalink)
Old February 20, 2013, 10:50 AM
great_big_abyss's Avatar
Oh yes, easily.
You'll also be impressed with the materials used on the cooler, too. That isn't plastic, it's metal. The name of the card lights up, too.
My 680 has the same cooler.... and i love it.
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; Sapphire HD5870; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; ASUS GTX650Ti Boost; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
  #25 (permalink)
Old February 21, 2013, 05:46 AM
Hehe...
I solved my 680 vs 670 performance questions... I went SLI 670.
A "go bigger" solution not totally unheard of for the users on this site I'd bet.
  #26 (permalink)
Old February 21, 2013, 06:14 AM
sswilson's Avatar
Heh... so did you order a second galaxy card or find a decent deal on a used 670?
  #27 (permalink)
Old February 21, 2013, 06:28 AM
I ordered a second one sswilson.
I thought the $350 each was a good deal for the Galaxy and each has a $40 rebate to boot.
Now to look at the Titan review Sky just posted = Eeeek!
  #28 (permalink)
Old February 21, 2013, 08:02 AM
Think you'll be happy with the performance of dual 670's vs the price of the titan..
If the titan were even close to 2 670's I would get it but as it is... I'm thinking of going for a second myself.
  #29 (permalink)
Old February 21, 2013, 08:22 AM
Will be my first time using SLI.
I've always built middle of the road gamer machines in the past and decided to splurge for a change.
Arrrg... and I just noticed the GPU rebate has a limit of 1 per customer. Ahhh well I guess I can live with it.
  #30 (permalink)
Old February 22, 2013, 07:49 AM
10e's Avatar
10e 10e is offline
Originally Posted by JayDeeHobbit View Post
Hmmm... my opinion was formed a few years ago and I believe the company was Galaxy. (not certain)
What happened with the company I'm thinking of was they decided to pull out of the North American Market and left people on this side of the pond high and dry.
You're probably thinking of Palit, which pulled out about 2.5 - 3 years ago IIRC.
Good purchase. That's an awesome card, and the dual fans are quiet. I've used the 680 version of it.
Dual GTX 670s are a great set-up.
And while it might seem like overkill for games at 1920x1200, you're more future proof when newer games with more demanding graphics come out.
Western Digital worth the extra premium? miggs78 Storage 18 June 20, 2012 08:39 PM
is this ram worth the extra 100$? Lambda Llama RAM 6 January 6, 2011 09:49 AM
Q6600 vs Q9550. The extra 150$ worth it? chouchou CPU's and Motherboards 12 November 18, 2008 03:24 PM
9800GTX worth the extra 60 bucks!! Need some advice tonight!! bushwickbill Video Cards 5 April 17, 2008 06:23 PM
Merc Stealth. Is it worth the 80 bucks? reaverclan Member Reviews 22 November 14, 2007 01:19 PM
