Old February 14, 2013, 01:48 AM
Patriote's Avatar
Default SLI 580GTX or single 680GTX
Hey guys!
It's been a while!
Well, I'm still alive and well! Anyways, So yeah, I've been using my Asus 580GTX DirectCuII since November 2011 and it's been kicking asses ever since. Any game I have thrown at it, it kicked it's ass. Now, as more (and new) games are released, I am starting to feel the need to upgrade. Plus, Crysis 3 is coming out and I'd like to be able to run it 1920x1200 all maxed out just like I did with Crysis 2. I averaged 35FPS with everything maxed out and my current set-up.
So my question is ... What would be a better (wiser) choice money/performance wise. Should I just go out and grab a second 580 GTX or sell it and grab myself a 680 GTX ? There is one thing tho... If I decide to go down the road of SLI (again), I will have to get rid of my Asus 580 GTX DirectCuII anyways since it's triple-slot and won't let me fit a second 580 GTX if I am correct as I have a PCI Sound card as well. So that's one thing to consider for the hassle if would be having to sell this one then find 2 'used' 580 GTX cards.
So, what are your 'experts' (mostly updated as I haven't kept track of whats HOT and whatnot recently) thoughts on this?
Thanks a lot guys!
**Specs in sig**
• - Asus P8Z68-V PRO
• - Intel I5 2500k @ 4.5Ghz (for now)
• - Asus Geforce 580GTX DirectCUII Fermi
• - 16GB Corsair Vengeance Low Profile
• - Ultra X3 1000 Watt
• - Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
• - Corsair Vengeance 1300 Gaming Headset
• - Crucial M4 SSD 128GB \ WD Caviar Black 1TB
• - CoolerMaster 690II Advanced
• - Dell UltraSharp 24''
• - Noctua NH-D14
Old February 14, 2013, 05:16 AM
turtletrax's Avatar
Hey! Good to see you my friend
These are always the troubles I find with SLi/Crossfire. Do I get another card, or get a new gen, then SLi that one later?
Based on the fact you would have to sell your one 580 and then get two more, I vote get a 680. That gives you the ability to keep your other slots free and have a pretty sweet card that is efficient, and gives you the option to SLi easily if you stick to dual slot. I have 680 SLi right now and run 2560x1600 and have no issues playing anything, and I don't bother OCing them at all. Only thing I see the 680 is weak at is CUDA and I have a 580 for anything I use that for.
Either way you go, I would keep your eyes peeled in shopbot.ca for good 580/680 deals and price match with Memoryexpress.com and get their Uber Pricebeat and get 25% of the difference. Sometimes you can get some pretty sweet deals.
Cant wait to see what you decide!
In progress: Other hobbies.
Old February 14, 2013, 06:42 AM
great_big_abyss's Avatar
I second turtletrax. Sell your 580 (I think you could get $250 - $300 for it) and go buy a new GTX680. Your system will consume less power (than with even just one 580) and run cooler and quieter. What's more, at 1920x1200 you'll be able to run anygame to come in the forseeable future.
If you're going to go that route, allow me to recommend the Galaxy GTX680GC. The heatsink shroud is made of aluminum, and looks just fantastic. More importantly, they have great customer service and an RMA center here in NA. I personally have one of these cards, and yes, while I'm sending it away for an RMA (could happen with any manufacturer's card), the process was quick and pain-free, made even easier by the fact that we have a Galaxy rep here on the forums.
You may be able to find it for cheaper somewhere other than NCIX, though. I didn't check anywhere else.
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; Sapphire HD5870; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; ASUS GTX650Ti Boost; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
Old February 14, 2013, 10:35 AM
680gtx all the way. Much less power consumption means a lower cost of ownership over time.
Old February 14, 2013, 11:06 AM
turtletrax's Avatar
True dat :) Also you can find some in the $440-$460 range. If you sell your 580 for a decent price should bea cheap upgrade for what you get.
Old February 15, 2013, 12:32 AM
Wait and see..!!few months may make a HUGE difference and a single 680 isn't that much of a bump for what you'll be putting into it.
Question on sli'ing the 580's.
Can you not put the Asus in a lower slot so the size doesn't matter?
Use an after-market cooler?
Buy a decent 2 slot cooler that someone doesn't need as they are under water or even a dead card just for the cooler?
Old February 16, 2013, 10:24 AM
Patriote's Avatar
Thank you all for your input! I will definitely go down the GTX 680 path! :) Does asking 250$ CAD for my Asus Geforce 580GTX DirectCUII sounds correct?
• - Noctua NH-D14
Old February 16, 2013, 03:34 PM
turtletrax's Avatar
I would say that is a fair price. Start there and see if it sells.
Another thing I would add to the GTX 680 from GTX 580 argument is I have seemed to notice a increase in PQ. I have the Dell U3011 and there seems to be an increase in sharpness somehow. Especially in Blu-Ray playback. Was a nice surprise.
Old February 17, 2013, 07:29 AM
"Quote This..."
I'd wait for the next gen. In fact that's what I am doing.
Black belt in CAPS LOCK.
Old February 17, 2013, 11:08 AM
Patriote's Avatar
That's a good news I have a Bly-Ray burner and a Dell Ultrasharp
• - Noctua NH-D14
[WTB] EVGA 580GTX 3gb jtf2 Buy/Sell & Trade 2 June 5, 2012 07:55 PM
580gtx 1.5gb vs 3 gb jtf2 Video Cards 10 July 28, 2011 04:21 PM
Single Loop or Dual Loop? Pump enough for single? MattC Water Cooling 5 May 31, 2011 07:19 PM
[FS] eVga 580GTX...NOT FOR SALE...Please Close... kazman Buy/Sell & Trade 8 May 10, 2011 07:26 PM
New single PCB 295 Realityshift Press Releases & Tech News 15 June 14, 2009 01:18 PM
