  #41 (permalink)
Old February 19, 2013, 08:46 AM
great_big_abyss's Avatar
Wow, that's actually quite high. Did you have AA enabled? If so, I'd say that anything over a GTX660Ti is indeed completely overkill for 1920x1080/1200.
Also, what processor did you play that on? Was that on your server? I'm just curious if those numbers came from your server, an Intel system, or if you have a bulldozer/piledriver that you used.
  #42 (permalink)
Old February 19, 2013, 09:06 AM
Soullessone21's Avatar
As per settings, just knocked it up to ULTRA on the top setting and everything set to ultra I will check tonight for you for AA, This was not on my server it was on my Gaming tower that was clocked down from the normal for it as my wife says the room upstairs is to hot when I play games.
Intel 980x at 3.6Ghz
24GB 1600 ram
660 TF OC
Win8 pro 64
Corsair 240gb Neutron
Intel LGA2011 Water Cooler AIO
Asus p6x58d premium
Server is having super heat issues till I get it into a new case with better cooling, I will test it as soon as that is resolved.
Good Bye HWC it was great :)
Site and Forum:
http://forums.realhardwarereviews.com/index.php
If you need me the link above is where I spend my days now
SLI or Single Card? pasteberlusconi Video Cards 17 August 19, 2011 10:23 PM
Recommendations for new card rolltideroll92 Video Cards 9 June 5, 2011 05:51 AM
Card recommendations Ghiness Video Cards 14 December 20, 2009 09:39 AM
BF2 Sound card recommendations Cowboy Gaming 11 October 7, 2009 02:30 AM
Video Card recommendations Maxtor Video Cards 28 February 20, 2009 04:35 PM
