  #21 (permalink)
Old March 2, 2013, 12:10 PM
Slik's Avatar
I thought SSD's had no impact for gaming. I know games etc. will load faster,but how does it increase,or enhance physx or frame rates?
EVGA DG 87 -i7 5930k @ 4.4ghz. Liquid cooled-4x4gb G Skill Trident X DDR3@ 2400mhz- EVGA x 2 1080 Ti Black SLI - Soundblaster X7 Sound Card- LG 34" Monitor-ATH AG1X Headphones-Butt Kicker Gamer-TrackIR 5
  #22 (permalink)
Old March 2, 2013, 12:21 PM
It doesn't, but it was the next piece in the puzzle so with my (now corrected) frame rate issue and everyone's suggestion's I pulled the trigger on it.
  #23 (permalink)
Old March 2, 2013, 04:31 PM
MARSTG's Avatar
Forcing a video card to render 3D and PhysX in the same time is not the optimal setup. You would need an additional nvidia card and set it up in Nvidia Control panel for the second card to do the PhysX acceleration alone. I heard a 9800GT should do the job but you could also go with something more modern like a GT430. So look for a used nvidia series 8000 or 9000 in the high end and you should be ok. Review here http://benchmarkreviews.com/index.ph...1&limitstart=8
  #24 (permalink)
Old March 8, 2013, 09:15 PM
Extract PHYSX Library DLL from the latest PHYSX installer and copy the Over the DLL's in ur borderlands install folder I did this to fix most of my physx slowdown but steam will overwrite the updated physx dll files eventually when it checks for updates
dedicated physx card Jaydu Video Cards 10 April 27, 2012 06:14 PM
GTX 580+GTX 275 Dedicated PhysX Rocyaic Video Cards 6 June 15, 2011 11:13 PM
Dedicated Physx thread Nevakonaza Video Cards 6 December 19, 2010 05:41 PM
Physx dedicated GPU and EVGA OC kendallcschm Video Cards 8 January 19, 2010 03:48 PM
Dedicated physX GPU MarkOne Video Cards 1 January 18, 2010 05:27 PM
