Old February 4, 2013, 11:14 AM
r0k0's Avatar
Default Radeon 6990 Drivers Installation problem
every time i try to install the 13.1 drivers for my 6990, while the screen flashes on / off at one point it turn off completely and i have to shut off my computer
anyone have a clue why it wont install the drivers properly ?
Main Rig
Intel Core i5 2500K - 5.0
Asus Maximus Gene-Z / Gene 3
4x 4GB Corsair Vengence DDR3-1600
AMD Radeon HD 6990 4GB 880 / 1300
Crosair 600T White / Enermax Revolution 920W
A-DATA 120GB SATA3 SSD / Seagates 1TB Spare SATA3
Canadian Eh ?
Old February 4, 2013, 11:19 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
The screen turning off during the driver installation procedure is normal on the HD 6990 if you don't COMPLETELY wipe the previous driver version.
Most of the time, it will completely turn off, you wait a few minutes, reboot manually and then enter Windows to discover everything installed correctly.
Old February 4, 2013, 12:35 PM
r0k0's Avatar
oh.... i guess i'll try it again then... but it didnt not do it when i got 12,11 installed, but i'll try and wai a few sky
thx
Main Rig
Canadian Eh ?
Old February 4, 2013, 02:11 PM
GT7R's Avatar
Generally speaking the 13.1's are not all that great for the 6990, they are made for the 7xxx cards... My 6990 worked best with the 12.6's.
Old February 4, 2013, 02:55 PM
bigFOIG's Avatar
Good luck with my 6990! :)
Old February 5, 2013, 12:59 AM
r0k0's Avatar
Alright i'll try the 12.6 when i get a chance
Thx bigfoig
Main Rig
Canadian Eh ?
Old February 7, 2013, 03:43 PM
r0k0's Avatar
K now im getting #@$%^@#$%@&$^ PISSED
Drivers tried : 12.1, 12.6, 12.7 with CAP3, 12.11 with CAP2, 13.1, 13.2 and 13.2 Beta
everytime i install a new driver, OPENCL will not install and CCC doesnt work, i went back to 12.11 since it worked the first time now i get the same $H!T
anyone have a clue why the drivers is not installing properly ?
i clean the drivers with Guru3d Driver Sweeper before any install
Main Rig
Canadian Eh ?
Old February 7, 2013, 03:51 PM
bigFOIG's Avatar
In terms of terms of 32-bit or 64-bit, are you installing the correct drivers? Almost certain it's not the problem though... But who knows.
Also, wipe the drivers clean and then Windows Update. Try that.
Old February 7, 2013, 03:55 PM
r0k0's Avatar
yup all been done and using 64bit drivers
Main Rig
Canadian Eh ?
Old February 7, 2013, 04:04 PM
bigFOIG's Avatar
Windows Update couldn't do it either?
OEM Radeon HD 6990 bigFOIG Price Check 2 January 14, 2013 12:03 PM
GTX295 installation problem great_big_abyss Video Cards 13 November 9, 2012 01:53 PM
[WTB] Radeon 6990 Raikkonen Buy/Sell & Trade 0 July 24, 2012 07:14 PM
