Old January 18, 2013, 03:39 AM
Default Upgrading Graphic Card
hey everybody, i hv a computer that my father build and it sucks for playing game because its still using the graphic card from the mobo, i want to upgrade it so i can play the games nice and smoothly
Here are the spec of my PC:
Proccessor : Intel Core 2 Duo E7500 2.93 GHz
Memory : 2GB DDR2
PSU : Simbadda 380W
Motherboard : Biostar G41-M7 ver 6.2
i hv a small budget arround 70$
can i buy something for upgrading my pc?
Old January 18, 2013, 03:46 AM
ZZLEE's Avatar
where do you live ? more fore sending you to a place fore parts.
Up grade Power supply.
Up grade GPU
Fore 700 canadian you can almost build a whole new system. ?
What type off games? List a few you want to play.
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old January 18, 2013, 04:02 AM
Im sorry i mean 70$ dor the budget (just edited that)
i live in Indonesia i hv arround 700K IDR
what do u suggest now?
I think its too small budget for upgrading
maybe playing something like crysis, darksiders or something else, on normal graphic setting is fine for me
just make the game run smoothly with normal setting
Old January 18, 2013, 04:15 AM
Actually,i'm afraid it would not be worth it,the whole PC is too slow i think.
Old January 18, 2013, 04:24 AM
OC-Guru's Avatar
Hi mate, for $70 I would recommend an SSD.
After that, upgrade your Power Supply and then buy yourself a nice low endish graphics card, I'd recommend something like a Radeon HD 5570 or 6670.. these cards shouldn't be too expensive and play games really well at lower resolutions (1280x1024 or 1366x768)
^^ Don't listen to this guy, you can get a load of performance out of your PC. see my girlfriends rig for ideas, her PC can play games even like GTA IV, Battlefield 3, etc.
Gaming rig: AMD Phenom II x6 1100T @ 4.4Ghz | 16GB 1600Mhz Crucial RAM | Gigabyte Radeon HD 7850 OC 2GB | Gigabyte 990XA-UD3 | OCZ Agility 3 60GB
Wife's rig: 2x Xeon E5335 @ 2Ghz (8C/8T) | 24GB DDR2 RAM | ASUS GTS 450 1GB | HP OEM Socket 771 Motherboard | 4x Seagate ST9900805SS RAID0
D3 BT - Crispe#2349 (EU) - add me! :)
Old January 18, 2013, 04:40 AM
Why is the SSD?
I hv a big enough hard drives :)
maybe i should save some money and then buy an power supply and the graphic card
how about it?
Old January 18, 2013, 04:55 AM
ZZLEE's Avatar
Power supply fist a 650 Watt or more. Seasonic or Higher quality
then maybe GPU 120 $ C to 150 $ C
I don't know much about buying parts in your area.
Mail order from Hong Kong would be my thought.
Old January 18, 2013, 05:17 AM
great_big_abyss's Avatar
Forget about upgrading the powersupply, you don't have enough money. Plus, the Powersupply you have is enough for the kind of card you can afford.
700K IDR (I'm assuming that means Indonesian Rupiahs??) will get you something like this: hDigital Alliance Radeon 5670
That should at least give you enough power to play all modern games at low settings, if not medium settings.
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; Sapphire HD5870; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; ASUS GTX650Ti Boost; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
My friend suggest me to buy Digital Alliance HD 4850
He has a 340watt power supply and he said that the graphic card works well
how about that?
Must i buy that one?
Old January 18, 2013, 05:42 AM
Yes having a SSD is really nice, but I would never recommend that for your needs. Your computer may not be the fastest, but it would definitively benefit from a new GPU (not a top of the line one). With your no name PSU it is hard to recommend anything because its like a time bomb where we don't know when it will fail dragging with it other parts (most likely). As others have suggested, getting a new PSU (a quality 400 or 450w would be plenty) would be a priority, then getting a new GPU would be more appropriate.
Now, if you want to take the risk, I would recommend at least getting a GPU which doesn't require much power. It won't be amazing, but still much better than what you currently have. I am not fully aware of recent models that fit these requirements. I know I did this for my gf for when I want to play games on her computer, I can play fine with lowered details.
please help,which graphic card to buy habs2habs Video Cards 12 August 29, 2012 08:40 PM
Will another graphic card fit? biagio1661 CPU's and Motherboards 3 January 15, 2012 01:21 PM
Looking to Upgrade my Graphic card siegfx Video Cards 10 December 4, 2011 02:34 PM
graphic card for PCI-X 64-bit/133 MHz slot jksynapse Video Cards 2 January 27, 2009 06:04 AM
