  #31 (permalink)
Old January 19, 2013, 10:23 PM
OC-Guru's Avatar
Originally Posted by kenanchristian View Post
Yeah maybe its too risky to buy the graphic card now
so what do u suggest for the psi i should buy then what graphic card?
Maybe i will save some money first before buy all the components :)
If you give me a link that you can buy a power supply from, I'll pick you a good'en :)
Gaming rig: AMD Phenom II x6 1100T @ 4.4Ghz | 16GB 1600Mhz Crucial RAM | Gigabyte Radeon HD 7850 OC 2GB | Gigabyte 990XA-UD3 | OCZ Agility 3 60GB
Wife's rig: 2x Xeon E5335 @ 2Ghz (8C/8T) | 24GB DDR2 RAM | ASUS GTS 450 1GB | HP OEM Socket 771 Motherboard | 4x Seagate ST9900805SS RAID0
D3 BT - Crispe#2349 (EU) - add me! :)
  #32 (permalink)
Old January 19, 2013, 11:15 PM
Maybe u can search it here Bhinneka No. 1 Computer Webstore in Indonesia, Toko Komputer Online
buy please choose the cheapest one that fits :)
so i musnt save too much money to buy the graphic card :)
EDIT:
Or u can give me names and i will ask the local store :)
  #33 (permalink)
Old January 20, 2013, 01:00 AM
OC-Guru's Avatar
Jual THERMALTAKE LitePower 600W [W0355RE] - Power Supply 600w - 1000w - Harga, Spesifikasi, dan Review
Jual COOLER MASTER Extreme Power Plus 500W Regular [RS500-PCARA3-EU] - Power Supply Below 600w - Harga, Spesifikasi, dan Review
I'd recommend something like these, it fits within your budget and will power any GPU you throw at it. :) even a 6750
  #34 (permalink)
I am not familiar with the vs line of power supplies from corsair, but they are generally very good as a brand. This is the cheapest one I would recommend for you.
Jual CORSAIR VS Series [CP-9020050-EU] - Power Supply Below 600w - Harga, Spesifikasi, dan Review
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
  #35 (permalink)
Old January 20, 2013, 09:02 AM
Soultribunal's Avatar
The only problem is those PSU's are far from the best for the money out there.
VS Series I believe is the Builder series equiv over here , with it only reconfigured to run on 230v exclusively instead of auto sense V control.
Jual SEASONIC Power Supply [S12II-520] - Power Supply Below 600w - Harga, Spesifikasi, dan Review
That is the one I would go with,
-ST
  #36 (permalink)
Old January 20, 2013, 09:13 AM
^^^that would be the one I would pick for my own comp as well. That said I know money is tight, and the Corsair one I linked is still very good and would suffice (but the seasonic is likely a bit better still).
  #37 (permalink)
Old January 20, 2013, 09:37 AM
Perineum's Avatar
I would definitely do the Seasonic.
Considering the OP just wants his games to run relatively smoothly I would opt out of an SSD. Yes, of course they are nice, but very few of the people I know in real life are actually running them yet until the prices/size come to a better place.
The OP could upgrade the video card in his machine, but it is very likely his POS PSU could just tank and take out everything else.
The Seasonic PSU will last for years, and even a second hand GTX260 would work well in his system.
  #38 (permalink)
Old January 20, 2013, 10:02 AM
Nothing wrong with the one you linked either, it is all about budget. Either will work fine :)
-ST
  #39 (permalink)
Old January 20, 2013, 10:32 AM
b1lk1's Avatar
I know it is double you budget, but putting an HD 7750 in there would not require a power supply upgrade and you'd get a major major boost in games.
SSD's are a waste of money.
MY HEATWARE
  #40 (permalink)
Old January 20, 2013, 08:44 PM
How about this combination?
Corsair VS450
Digital Alliance 5670 2GB
please help,which graphic card to buy habs2habs Video Cards 12 August 29, 2012 08:40 PM
Will another graphic card fit? biagio1661 CPU's and Motherboards 3 January 15, 2012 01:21 PM
Looking to Upgrade my Graphic card siegfx Video Cards 10 December 4, 2011 02:34 PM
graphic card for PCI-X 64-bit/133 MHz slot jksynapse Video Cards 2 January 27, 2009 06:04 AM
