  #21 (permalink)
Old January 18, 2013, 10:01 AM
Thats what i mean
i dont know i read it somewhere, but the graphic card has the maximum screen res, is it right?
Im never upgrading the graphic card so i just know a little about that
But anyway, thanks a lot for all ur suggestion and answer :)
Its a big help really :D
  #22 (permalink)
elmorejohn46's Avatar
I would go with a 2g 7850 because og the extra memory and it is faster,but it comes down to how much money you want to spend
Intel-i7-3820+Corsair H-100+Gigabyte X79-UD5+16g G.Skill 1666DDR3+256g Crucial-SSD+1-3TB Seagate+2-1TB-Samsung+1-640g- WesternDigtal+SLI-ASUS DIRECT CU II GTX-670+LG-12x Blurner+Logtech G9x-mouse+G-110-keyboard+Driving Force GT Wheel+Pioneer VSX-1020K+Polk Audio Speakers+LG-50"Plasma PM6700+Antec-P280+XFX 850w PRO Semi-Modular
  #23 (permalink)
Old January 18, 2013, 10:05 AM
great_big_abyss's Avatar
If you can find a 7850 for less than 700 000 indonesian rupiahs, please feel free to post a link.
  #24 (permalink)
Old January 18, 2013, 11:49 AM
7850 for less than 70bucks LOL -_-
  #25 (permalink)
Old January 18, 2013, 01:48 PM
OC-Guru's Avatar
Originally Posted by kenanchristian View Post
Why is the SSD?
I hv a big enough hard drives :)
maybe i should save some money and then buy an power supply and the graphic card
how about it?
Well, hard drives are realllyyy slow compared to SSDs.. if you put an SSD in your system, you'd get a lot faster boot times and applications would load faster. :)
My friend suggest me to buy Digital Alliance HD 4850
He has a 340watt power supply and he said that the graphic card works well
how about that?
Must i buy that one?
The HD 4850 is okay.. but a tad old, I see someone recommending a 5670, I would much rather that.. although your current power supply is my main worry.
Originally Posted by Kilauea View Post
Yes having a SSD is really nice, but I would never recommend that for your needs. Your computer may not be the fastest, but it would definitively benefit from a new GPU (not a top of the line one). With your no name PSU it is hard to recommend anything because its like a time bomb where we don't know when it will fail dragging with it other parts (most likely). As others have suggested, getting a new PSU (a quality 400 or 450w would be plenty) would be a priority, then getting a new GPU would be more appropriate.
Now, if you want to take the risk, I would recommend at least getting a GPU which doesn't require much power. It won't be amazing, but still much better than what you currently have. I am not fully aware of recent models that fit these requirements. I know I did this for my gf for when I want to play games on her computer, I can play fine with lowered details.
As mentioned above, I am more worried about his power supply rather than his GPU or if he has an SSD or not :) I would upgrade the PSU before even touching any graphics card
Edit:
I see people talking about getting a HD7850? Please don't post complete nonsense.. his PSU nor budget would fit that card.
Gaming rig: UNDER CONSTRUCTION!
Wife's rig / D3 Bot PC: 2x Xeon E5335 @ 2Ghz (8C/8T) | 24GB DDR2 RAM | ASUS GTS 450 1GB | HP OEM Socket 771 Motherboard | 4x Seagate ST9900805SS RAID0
D3 BT - Crispe#2349 (EU) - add me! :)
  #26 (permalink)
Old January 19, 2013, 06:58 AM
Yeah i know my PSU is the main problem
but i think i will take the risk and buy the graphic card
the HD4850 have a better clock speed than the 5670, some people i asked chose the 4850 the other people chose the 5670
Now im confused what graphic card i will buy
can u tell my which one and why?
  #27 (permalink)
Old January 19, 2013, 09:39 AM
Bond007's Avatar
Wow.....you are getting some really mixed (and in my opinion pretty bad) recommendations. Given your budget and power supply find a cheap hd5670 (as some others have mentioned), hd 6670, hd 5750, or hd 6750...that is the order from slowest to fastest for graphics, so the 6750 would be the best if you can find one in your budget.
I would not recommend a 4850. It is now old technology that will use more power and make more heat.
EDIT: That all said, it would be best if you had a bit more money available so you could get a better power supply and a graphics card.
  #28 (permalink)
Old January 19, 2013, 10:04 AM
Soultribunal's Avatar
I wouldn't take the risk.
Your PSU goes and then what have you accomplished? Nothing. Dead computer at most. Spend some money and get a half decent PSU, something new that you can transfer over to a new Rig when you have the $$$.
My thoughts.
-ST
www.realhardwarereviews.com
  #29 (permalink)
Old January 19, 2013, 02:47 PM
OC-Guru's Avatar
My thoughts.
-ST
^ This
People are forgetting that the PSU is the main function of the computer.. if that goes, his whole PC is going down with it.
Put a HD 6750 in his computer and watch it blow up.
Estimated Power usage with a HD 5670:
System Type: 1 physical CPU
Motherboard: Regular - Desktop
CPU Socket: Socket LGA 775
CPU: Intel Core 2 Duo E7500 2933 MHz Wolfdale-3M
CPU Utilization (TDP): 90% TDP
RAM: 2 Sticks DDR2 SDRAM
Video Card 1: AMD Radeon HD 5670
Regular SATA: 1 HDDs
DVD-RW/DVD+RW Drive: 1 Drive
Additional PCI Card (avg): 2 Cards
USB: 3 Devices
Front Bay Card Reader: Yes
Fans
Regular: 2 Fans 120mm;
Keyboard and mouse: Yes
System Load: 90 %
Minimum PSU Wattage: 244 Watts
Recommended Wattage: 294 Watts
Basing that off of a standard PC.. I'm not sure what else he has floating about in his computer.
  #30 (permalink)
Old January 19, 2013, 06:46 PM
Yeah maybe its too risky to buy the graphic card now
so what do u suggest for the psi i should buy then what graphic card?
Maybe i will save some money first before buy all the components :)
please help,which graphic card to buy habs2habs Video Cards 12 August 29, 2012 08:40 PM
Will another graphic card fit? biagio1661 CPU's and Motherboards 3 January 15, 2012 02:21 PM
Looking to Upgrade my Graphic card siegfx Video Cards 10 December 4, 2011 03:34 PM
graphic card for PCI-X 64-bit/133 MHz slot jksynapse Video Cards 2 January 27, 2009 07:04 AM
