Old January 10, 2013, 02:54 PM
Rollergold's Avatar
Default Interesting 680 situation
Got a couple of 680's in SLI and I decided to slap on the 3 way SLI bridge since the orange, floppy, 2 way bridge Asus includes just sticks out like a sore thumb but when I started up the machine again with the 2 way bridge the Nvidia control panel said "Connect the 2 SLI ready Graphics Cards with an SLI connector", OK?
So I try a different 2 way bridge same result. Put the 3 way back on, disabled SLI, shut the machine back down and put the 2 way back on, same result.
Even tried disabling SLI, removing bridge, totally removing the graphics driver, rebooting the machine after uninstall, then redownloading and reinstalling the latest driver and still these 680's seem hell bent in only doing SLI with the 3 way bridge.
This doesn't effect my frame rate or use of the cards in any way but I find it interesting that these 2 cards are being picky about which SLI bridge is connecting them together
Asus P6X58-E WS | i7 920 D0 @ 4.01ghz W/ Apogee HD Block | 24gb (3x 8gb) Corsair Vengeance 1600 | 2x EVGA GTX 680 SC's in SLI W/ XSPC Razor Blocks |
4x 1tb WD Black Drives | SB Recon 3D PCIe | Swiftech MP655-SE Pump | Swiftech Maelstrom Res | CM HAF 932 | Corsair HX 850 (3 yr's old) | Asus VH236H + PA238QR
Old January 10, 2013, 03:33 PM
ZZLEE's Avatar
try flipping end fore end the 2 way bridge.
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old January 10, 2013, 04:12 PM
G777's Avatar
You could also trying swapping the cards, no idea why but sometimes that fixes sli problems
Old January 10, 2013, 04:49 PM
Rollergold's Avatar
I actually tried swapping card placements but nothing. Its not really causing problems per say but its kinda interesting that they are acting like such brats
Old January 10, 2013, 04:58 PM
Arinoth's Avatar
Have you made sure that all your monitors are plugged into the primary card? Any monitors plugged into the 2nd card automatically disables sli UNLESS you setup nvidia surround. I know this as I have 3 monitors hooked to primary card, without surround enabled but have sli enabled and working.
Old January 13, 2013, 08:33 AM
norfolk's Avatar
I have 2 monitors going into the primary card and I am getting the same results as Arinoth
Old January 13, 2013, 09:24 AM
KaptCrunch's Avatar
rollergold i see bios 0301 fixes issue with dram OS report
are both cards same manu and model ?
check the video slots if any flat connectors are flatten....use a safety pin to re-arch contact note no power to MB when doing so
Old January 13, 2013, 10:34 AM
Rollergold's Avatar
Both cards are the very same make and model and none of them are reporting anything funny with the ram and I'm not getting any performance decrease or instability.
Old January 13, 2013, 10:49 AM
KaptCrunch's Avatar
run the intel inf utility
need help. strange firefox situation hohohee O/S's, Drivers & General Software 4 December 4, 2011 10:16 AM
PCI-E or AGP in this situation AmuseMe Video Cards 25 March 25, 2010 04:49 PM
Very bad situation! mailaw Troubleshooting 32 April 28, 2009 05:23 PM
An annoying situation... TwystedMonkey Off Topic 10 May 27, 2008 10:26 PM
