-   -   ASUS Releases ARES II Graphics Card w/ Dual HD 7970 GHz Cores (http://www.hardwarecanucks.com/forum/video-cards/59000-asus-releases-ares-ii-graphics-card-w-dual-hd-7970-ghz-cores.html)
SKYMTL January 7, 2013 11:02 AM
Featuring dual AMD Radeon HD 7970 GHz Edition GPUs, 6GB GDDR5 memory and a liquid/air cooling system the ARES II redefines graphic performance.
AMD never did release their rumored HD 7990 but they have left designs for dual HD 7970 designs in the hands of their capable board partners. PowerColor was first out of the gate with the fairly impressive Devil 13, a massive card that featured two overclocked HD 7970 cores and an epic cooling assembly. Now ASUS is getting into the game with the ARES II.
Read more here: ASUS Releases ARES II Graphics Card w/ Dual HD 7970 GHz Cores | Hardware Canucks
great_big_abyss January 7, 2013 11:14 AM
Wow. What a novel cooling system. About time we see an LCS for a video card. I wonder if we'll ever see aftermarket LCS's at all, or if the current crop of GPU's are just so damn efficient that a single GPU card would never warrant such a solution.
Anyways, I can't wait to see some benchmarks from this thing. I'm not entirely convinced that AMD has caught up to Nvidia when it comes to Crossfire vs SLI efficiency and scaling (as was shown with the Devil 13). I suppose it may have to do with the bridge chip that is inevitably included on this card.
EDIT:
Sky, maybe you can explain something to me.
The new generation of chips (Tahiti and Kepler) are arguably more efficient than their predecessors (Cayman and Fermi) providing more performance with lower power consumption.
http://images.hardwarecanucks.com/im.../HD7970-63.jpg
Look at the comparison here between the 7970 vs the 6970. The 7970 is drawing 9 less peak watts than the 6970.
So, why then, does the 'new' generation of AMD Dual GPU cards (Devil 13 & Ares II) require three 8-pin power connectors, while the previous, more power hungry dual GPU 6990 required only two? What makes these new dual GPU cards so much more power hungry than their predecessor, or even the GTX690?
SKYMTL January 7, 2013 11:18 AM
I see one issue with it though: Say I have one of the many cases with a single rear exhaust fan but I'm already using an AIO unit for CPU cooling. What then?
great_big_abyss January 7, 2013 11:24 AM
1) See edit above
2) In my case, I would install the CPU LCS as it already is, exhausting air out the back of the case. I would then install the GPU LCS to intake air through the bottom of the case, through a dust filter, of course. Alternatively, I could remove the case's front intake fan, and use the GPU LCS to either intake or exhaust in it's place, keeping an eye out for positive pressure.
Then again, I have a case that was designed around a plethora of cooling solutions, so depending on your case, YMMV.
SKYMTL January 7, 2013 12:08 PM
They don't "require". Like any good e-peen contest, # of connectors is being used as a purely marketing-focused initiative.
However, that isn't to say that extreme overclockers won't need the added current at some point....
Dzzope January 7, 2013 01:48 PM
Most cases these days have top and side mount points for cooling, not to mention bottom or front (if it would reach),
I would expect some one that dropping probably ~$900 - $1100 on a GPU to be able to get a new case to suit or have theirs mod'd so it can take it.
Not really a valid "against" point IMO
I am interested to see how good the crossfire is on it though.
On the 6990.. weren't they running cut down / scaled back cores to keep the power and heat in-check...
That they are running 2 full version ghz edition cores and overclocking them shows how much better they are.
BigPhatPaulie January 8, 2013 08:07 AM
The 6990 was running lower clocked chips but they could be ran at regular 6970 levels with a flick of the switch.... LOVE this card on the other hand I want it badly... Just not a huge fan of it being amd (bad experience with drivers) but hey maybe this card is different
bliz January 8, 2013 08:19 AM
I think it's a bit late to release it,new series coming,so...i don't think a lot of people will buy it...
It's more a product for the fans of epicness i think,and for collections^^.
three 8pin, smells like 400w+
SKYMTL January 8, 2013 09:53 AM
There's always a new series coming. If manufacturers had only that in mind, they'd only release reference versions....
Soultribunal January 8, 2013 10:18 AM
Variety is the spice of life, I am okay with these units, not that I can afford them but I like the engineering that goes into them.
-ST
