  #21 (permalink)
Old January 10, 2013, 06:57 AM
Pabz0r545's Avatar
I'm not a huge fan of this. Water cooled block but with an 80mm fan for air cooling. That thing is probably going to SCREAM! Part of the whole idea of water for many people is silence.
Also what happens when you have a H80i or something installed on your cpu and the radiator to the rear of the case. How is anyone goiong to run more then 1 of these?
"Water cooling is basically like injecting drugs into your veins and you'll find that what once was enough is quickly not enough anymore."
-Linus
  #22 (permalink)
Old January 10, 2013, 07:19 AM
great_big_abyss's Avatar
As was mentioned above, most modern gaming cases these days have provisions for many locations of fans and rads. I forsee an H100i on the top panel of a case, one ARESII blowing out the back panel, and one ARESII blowing up from the bottom. Or some variation of this.
And, the little 80mm fan wouldn't have to blow that fast. It's just to cool the VRM's and Heatsinks, and TBH I don't think those require that much cooling. That little fan is just to get some semblance of air movement over those components.
Although, Why ASUS wouldn't try to go with a full cover water block hooked up to the AIO system, and try to go for a single slot card, is beyond me. That would be a much more attractive solution, especially for the money you'll likely pay for this beast.
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; Sapphire HD5870; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; ASUS GTX650Ti Boost; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
  #23 (permalink)
Old January 10, 2013, 08:51 AM
Why? dual 80mm fans are not that noisy,i guess that they won't use a rubbish fan,and there is only one,and the watercooling fan is prolly a quiet 120,seems good no?
  #24 (permalink)
Old January 10, 2013, 10:24 AM
Brian@NCIX's Avatar
NCIX System Builder
Don't think so, for those who don't want to risk the chance of breaking the card when jerry rigging an h100 on to it, this is a pretty fantastic solution. (If you have the $$$)
The 80mm is there to cool the VRM and board, I don't think it would even begin to be audible for the most part.
For the amount of space it takes, you're looking at the cooling performance of a Kuhler 920/H80, as opposed to the super massive DIRECTCU's & Matrix's, which probably don't even begin to compare thanks to heatsink restriction.
I doubt whoever buys this would have the problem of not enough 120mm outlet/inlets, even the cheap mid size towers come with a bottom inlet, worse comes to worse, mount it to the side panel.
  #25 (permalink)
Old January 10, 2013, 10:43 AM
NyteOwl's Avatar
Might be a nice option in a HAF XB case. The ATI rad on one side in front and the CPU rad on the other. Rear exhaust for remaining heat ...
Obsolescence is just a lack of imagination.
  #26 (permalink)
Old January 10, 2013, 11:06 AM
It would makes the corsair 900D useful
ASUS Launches the Radeon HD 7970 DirectCU II TOP Graphics Card Sam_Reynolds Press Releases & Tech News 12 February 3, 2012 04:09 PM
ASUS Dual GTX 480 "MARS II" Graphics Card Spotted FiXT Press Releases & Tech News 26 July 19, 2010 01:18 PM
ASUS ARES ROG Card Spotted Soultribunal Press Releases & Tech News 11 April 12, 2010 09:41 AM
ASUS Designs Monster Dual-GTX 285 4 GB Graphics Card MonsterSound Rumor Mill 24 November 15, 2009 04:25 PM
ASUS Designs Own Monster Dual-GTX 285 4 GB Graphics Card cadaveca Press Releases & Tech News 15 May 29, 2009 08:50 PM
