Old December 26, 2012, 09:11 AM
Default Video Card not working?
Well, I'm back again lol. So, my parts came today and I put the PC together. The screen wasn't showing so I took out the video card and put my DVI cord in the onboard gfx card and it works fine.
PC SPECS:
CPU: i7 3770k
MOTHERBOARD: ASROCK Z77 PRO4
GPU: 660Ti EVGA FTW EDITION
PSU: CORSAIR AX750
RAM: CORSAIR VENGEANCE 16GB
CASE: THERMALTAKE MK1 (or whatever it's called)
Old December 26, 2012, 09:37 AM
Few questions:
Was the card working fine in your previous build?
Had all the power connectors attached?
Did you select to have pci-e graphics over IGP (or whatever terminology they use) in the bios?
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
KaptCrunch's Avatar
ok your on PCI (MB)video you need to change in bios NorthBridge set-up to PCI-E (slot)
put back your video card ..system off make sure power connections are in to card
boot in to bios and change to PCI-E then save
if screen goes blank or it reboots to black screen then remove moniter cable from MB video port and move it
to your video card primary port if has 2 ports
Old December 26, 2012, 09:49 AM
Originally Posted by Bond007 View Post
Few questions:
Was the card working fine in your previous build? Yes
Had all the power connectors attached? Yes
Did you select to have pci-e graphics over IGP (or whatever terminology they use) in the bios? Not yet.
Old December 26, 2012, 09:54 AM
It was already selected as that
Old December 26, 2012, 11:48 AM
KaptCrunch's Avatar
thats werid onboard video not default
try resetting cmos by remove AC powercord from PSU and push start button to drain power, then reset cmos and replace jumper then power up
for manual say looks pci-e slot first by default
another thing is MB firmware up to date ?
Old December 27, 2012, 01:22 PM
UPDATE: I fixed the problem!
Old December 27, 2012, 04:44 PM
What was the issue?
S video isn't working on my Vid card how can I test it? Shadowmeph Troubleshooting 6 October 5, 2009 04:34 PM
Secondary USB Display not working with ASUS Video card Brad P Troubleshooting 1 May 23, 2009 06:48 AM
Help! Card Not working fully? DavidDemise Video Cards 14 March 16, 2009 03:15 AM
Thumbnails for video files not working ipaine O/S's, Drivers & General Software 6 February 21, 2009 07:35 PM
HD3870 video inputs on vista not working? vinister Video Cards 3 April 9, 2008 07:40 PM
