-   -   Intel HD Graphics code 12 (http://www.hardwarecanucks.com/forum/video-cards/58575-intel-hd-graphics-code-12-a.html)
Evil Genius Jr. December 16, 2012 09:19 AM
This:
https://lh4.googleusercontent.com/-f...80/Drivers.png
Prevents Lucid MVP from installing. I have uninstalled and re-installed both GPU drivers multiple times and in different orders but to no avail. Any ideas?
Thanks!
Soultribunal December 17, 2012 02:21 PM
If you are using a discrete GPU, disable the onboard manually in the BIOS. That might help with the issue you are currently up against. Probably a conflict because your board sees both.
-ST
Evil Genius Jr. December 17, 2012 02:34 PM
Thanks for the reply!
There is no option to disable the GPU that I can see, only options to select primary adapter and shared RAM size. I'm using an ASrock Extreme4 Z77 mobo, am I just missing it? Also if possible I would like to keep it enabled and use lucid virtu mvp, but if it won't work that's fine.
Soultribunal December 17, 2012 02:39 PM
I can't say I have worked with the program you are talking about. Why does it need the onboard vs the Discrete?
BIOS might call it something different, I'll see if I can find some BIOS screen shots to help.
-ST
Evil Genius Jr. December 17, 2012 02:41 PM
-ST
It uses both, supposed boosts performance. A little down the page.
ASRock > Z77 Extreme4
And thanks! I'm lost with this UEFI stuff, still used to good old keyboard only BIOS.
Soultribunal December 18, 2012 10:29 AM
You know what, in my honest opinion, nothing good is going to come from using that tech to compliment your discrete GPU.
I would disable it all and just go with your Discrete. Even AMD's hybrid x-Fire is very limited, so I can only imagine how limited in application this will be. Lots of marketing though...
-ST
dandelioneater December 18, 2012 10:41 AM
I would agree with just disabling it and save yourself the hassle. I didn't really find that MVP provided any boost in performance while gaming with my 7970. I thought maybe it would help at idle with power consumption, but I didn't really notice that either tbh.
Evil Genius Jr. December 18, 2012 10:44 AM
Okay thanks guys! Will disabling it in the control manager work or do I have to do it in the BIOS? I can't find it lol, I see the options for iGPU memory, disable multi-monitor support etc. but nothing on disabling the igpu itself.
Soultribunal December 18, 2012 11:06 AM
Seeing as how I have never used that version of BIOS, my honest suggestion (and ASRock is pretty good at this) is asking them.
I am sure in BIOS there has to be a way to force just the discrete GPU.
I just do not know specifically for your application,
-ST
Evil Genius Jr. December 18, 2012 11:18 AM
-ST
Okay Thanks, figured out lol. For anybody reading this:
Advanced>
North Bridge configuration
Set Primary Graphics adapter to PCIE (obviously)
Set Share Memory to Auto (for some reason doesn't work in manual)
Set IGPU multi-moniter to disabled
Set Render Standby to disabled
Set Deep Render Standby to disabled
That should disable the IGPU.
