-   -   memtest for GPU's (http://www.hardwarecanucks.com/forum/video-cards/58572-memtest-gpus.html)
great_big_abyss December 16, 2012 06:58 AM
memtest for GPU's
I suspect I may have a memory problem on my GTX680 (games continuously crash). I need a recommendation for a suitable GPU memtest...
sswilson December 16, 2012 07:45 AM
Maybe memtestcl from the FAH community? Folding@home - DownloadUtils
Other than that, most folks would just use whatever GPU stress testing program they could get their hands on (make sure you monitor gpu usage to ensure that the drivers aren't throttling it back) and RMA based on general failure rather than discriminating between GPU/Mem as being bad.
YoungMan December 16, 2012 08:13 AM
I use Video Memory stress Test for Clean Environment (vmtce)
VMTCE | Free System Administration software downloads at SourceForge.net
You can run it in Windows or boot directly into the .iso. I use the latter with YUMI on a bootable usb drive with other diagnostic tools.
Although I find using furmark and running the benchmark to check for artifacting does the job much better and quicker.
