-   -   GTX 660Ti 3GB v. GTX 670 2GB (http://www.hardwarecanucks.com/forum/video-cards/58528-gtx-660ti-3gb-v-gtx-670-2gb.html)
concinnity December 13, 2012 01:34 PM
Which would run better on a 2560x1600 monitor? I play fairly demanding games like Far Cry 3, Battlefield 3, Borderlands 2, etc.
BeaverBender December 13, 2012 02:08 PM
Depends on what you're testing. You need to define that. Is this for games? If so, which ones? Is this a single or multi-monitor setup? What resolution? etc., etc., etc....
Bond007 December 13, 2012 02:27 PM
Unless you are running VERY high res and only in a select few scenarios would I give the edge to the 660Ti.
dandelioneater December 13, 2012 03:14 PM
As 7 of 9 would say: "3 Gigs is Irrelevant"
Marute December 14, 2012 12:26 AM
As Bond007 also said the thing is that the 3gigs will help you only if you are running extremely high resolution and multiple monitors. Assuming you are running 1080p (most are) the 670 will by far be the faster card. So I'd put my money there definitely.
